Go to Post (psst... what's the difference between a geek and a nerd?) - sonicbhoc [more]
Unread 05-01-2011, 18:22
ErikRantapaa ErikRantapaa is offline
FRC #2532 (Flash Power)
ErikRantapaa is an unknown quantity at this point
VIs stop running after two seconds
On one laptop I am having a problem with VI's terminating a couple of seconds after deployment.
For instance, when running the Analog Input example I can deploy the VI, and it appears to run, but then it just stops after a couple of seconds. No error dialog box comes up - apparently the VI goes from running mode to stopped mode.
Other symptoms:
- the status led on the cRIO will start to intermittently blink three times (i.e. blink-blink-blink, pause, blink-blink-blink, pause, ...)
- the driver station indicates there is no communication with the cRIO
- if I single step through the code, I never make it through one iteration of the inner while loop; the top branch of the OR operator connected to the stop condition becomes true right away; if I remember the VI correctly, this is an error condition, but I haven't been able to figure out what the error is.
However, I don't have these problems on another laptop. The main difference between the two is that on the one that works I installed Windows 7 myself and the one that doesn't has a factory installed Windows 7.
Any ideas of what the problem is? Is there more I can do to diagnose the problem?
Thanks!
Unread 05-01-2011, 19:48
Re: VIs stop running after two seconds
Since it sounds like single stepping is an easy and quick way to reproduce the issue, I'd recommend placing probes on a few wires, or perhaps turning on execution hilighting (the light bulb on the toolbar), and stepping through the code to determine if there is a logic issue, what error may be reported, etc.
By the way, if there is an error you'd like to look up, there is a tool in the Help menu called Explain Errors which lets you type in the code and get some additional info.
If it still doesn't make sense, post a screenshot or attach a VI to help narrow it down.
Just guessing, it sounds like the VI is finishing because the loop and all other code has completed. When a LV VI terminates, there are no lights or dialogs, it simply set the arrow back so that you can run again.
Greg McKaskle
Unread 05-01-2011, 20:06
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
One other thing to add:
According to http://digital.ni.com/public.nsf/all...256FDB00681951, a sequence of three flashes on the status LED indicates safe mode -- check the DIP switches (is the safe mode one different from the rest)? This might not apply to the FRC cRIO, but it probably does.
I hope this helps.
Unread 05-01-2011, 22:39
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
You can find how to configure your dip switches on page 12 of the crio-frc_Operating_Instructions.pdf.
You can get to this from the start menu by going to Programs > National Instruments > CompactRIO > CompactRIO Manuals
This will open up the CompactRIO Manuals folder containing the crio-frc_Operating_Instructions.pdf, found at C:\Program Files\National Instruments\CompactRIO\manuals
-- Marshal Horn
Problem with breakout box after update two Sarah348 Control System 1 12-02-2010 12:18
TeleOp Init/Stop vs. Auton-Iterative Init/Stop Ziaholic NI LabVIEW 11 07-02-2010 22:19
Any teams build two robots to practice with after build season. (6 weeks) GVDrummer General Forum 42 24-01-2008 21:34
pic: 166 Before and After: All in Two Hours Dan Petrovic Extra Discussion 3 30-06-2006 16:43
Stop The "Lesser of two evils" MattK Chit-Chat 8 07-08-2004 23:31
