Go to Post Brainstorming and creativity are great, but you do actually have to build the ideas you come up with sometime. - Chris is me [more]
Unread 08-01-2011, 12:32
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Drivetrain First Thoughts?
A drive system like the Omni or the Mecanum seems most fit for this year's game. Any first minute thought? The drive train I spend hours making yesterday came out to be useless for this...
Unread 08-01-2011, 12:36
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: Drivetrain First Thoughts?
The key to the small robot will be making something that's FAST! I don't know how putting the minibot higher on the pole will play out right now, but it seems interesting.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 08-01-2011, 12:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
My initial thought is KISS. No obstacles or special terrain means my initial reaction is the tried and true 6WD drop.
All subject to change as I go through game and strategy analysis of course.
Unread 08-01-2011, 12:56
lexxasaurus's Avatar
lexxasaurus lexxasaurus is offline
AKA: Lex
FRC #1727 (REX)
lexxasaurus is an unknown quantity at this point
First thing I thought was fast, I think speed will be fairly important in this game. The faster you complete the objective the more you get to block the other alliance. My next thought is strength; I feel having a stronger drive train will give you an edge in blocking... then there is the being able to move any direction giving you an advantage in scoring because of maneuverability.
Drive train this year seems really dependent on what you team wants to do, not the field elements.
Unread 08-01-2011, 12:58
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Speed seems quite important. I too am inclined to go with 6WD.
Unread 08-01-2011, 22:49
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
My first thought was
Tank drive will never work, since you have such an awful turning radius, unless your scoring system is seperate from the direction the robot is facing.
Next I thought Mecanum, since they can go sideways, and line up great for an elevator style scorer. But then I realized that mecanums are quite slow, so its quite a conondrum.
Could someone outline why 6WD would be good for this year?
Unread 08-01-2011, 22:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
6WD drop-center is doable with the KOP drive train straight out of the box, that's why it's so good for this year. IT WORKS right outta the box, and at a good, balanced speed too. It's good enough that veteran teams should already have the KOP drive train built by the end of today and can now work on their manipulators.
GitHub
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Well... go big or go home. 8wd swerve!
1058 PVC Pirates 2016 - xxxx
Unread 08-01-2011, 22:57
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I was thinking more like 8 wheel omni... Like a giant octagon
LOL JK I got something cooler.
Unread 08-01-2011, 22:55
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
My team is most likely going to use the same mecanum drive as last year, as it'll allow for much easier self-alignment to the pegs (and therefore less error while placing the tubes). We'll just slide along the endline while everyone else will be trying to turn with their clunky 6WD
EDIT: @Grim Tuesday: D'you mean that mecanums are slow going sideways? I agree, but a crabwalk shouldn't last for more than a few feet to align to pegs, so it would be more advantageous to have the additional maneuverability -- sliding > turning
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 08-01-2011, 22:58
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
Our team is heavily considering our first (successful) swerve drive this year. We figure that extra maneuverability while placing the tubes on the pegs will be extremely helpful. You can also lock the modules in place and run it as a tank drive so we have that option as well. We're hesitating a little because, although we built it during the offseason, we never have tested the electronics or controls (which people say is the harder part)
Otherwise, we'll go with a standard 6WD dropped center. It's simple, easy to make, and we'll be done with it in the first week.
Unread 08-01-2011, 23:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I think a 4 wheel drive is sufficient. You don't need as much mobility as last year's game required. As long as you have an accurate racking mechanism, I don't think the drive matters as much.
Unread 08-01-2011, 23:11
Chris is me's Avatar
AKA: Pinecone
Check the 60" rule, make sure you know how accurate you can actually be.
Unread 08-01-2011, 23:19
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Actually, in this game EVERYTHING matters. I say that because this is one of those games where for the most part everyone will be able to do everything. What matters is being able to do it better. With this in mind, better means you need to place more tubes than others (aka. you need to be faster.) In the end the teams that excel will be those that took the extra time to shave off seconds from their tube handling process (from the ground/ feeder to peg). The drivetrain is also a huge part of this. If your drivetrain is unreliable you won't be able to excel.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 08-01-2011, 23:32
mcrawford mcrawford is offline
Zac Efron-461
FRC #0461 (West Side Boiler Invasion)
mcrawford is an unknown quantity at this point
Everything does matter and if the max is scored of 158, the minibots are worth 32% and 68% for scoring tubes. The best option for drive trains is mecanum because of the maneuverability and being able to move to each of the different pegs left to right with out having to turn. I think it is going to be really hard to be fast just because the robots will constantly get in the way of each other making high speeds fairly dangerous if you hit another robot that is also going full speed. Also unlike last year robots aren't competing against the same objects.
