Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Unread 08-01-2011, 13:23
IFB662 IFB662 is offline
FRC #0662
IFB662 is on a distinguished road
Motor for mini-bots
What kinds of motors can we use for the mini-bots. At first I thought it was just the nxt motors which are slow. Anyone find any other ones we can use.
THE ONE THE ONLY ILLUSTRIOUS FILE BOY
Unread 08-01-2011, 13:26
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Motor for mini-bots
<R92> defines the restricted list of components a minibot must be constructed from.
This list includes the motors that may be used.
-Michael Dessingue
Unread 08-01-2011, 13:33
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Can't you kinda just "shoot" it up there?
Unread 08-01-2011, 13:44
The Deployment definition and <G20> states that because the minibot is considered an extension of the robot, it must be deployed below the deployment line on the tower.
-Michael Dessingue
Unread 08-01-2011, 13:47
FRC #0662
Yeah we were thinking of a fly wheel that you spin up on your bot then you let losse on the pole. Do people think that's legal.
Unread 08-01-2011, 13:53
Possible? If a 15-lb, 12" diameter or less flywheel can make it up the pole without falling off, I'll be surprised.
Safe? I'm thinking no, because if you miss, that's a lot of energy going somewhere. Hopefully it's shielded enough that it doesn't go straight towards other robots/people's feet when they come on the field/that sort of thing--which further reduces available weight/diameter.
Legal? Questionable (on safety). Ask Q&A.
Unread 08-01-2011, 14:02
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
TETRIX DC Drive Motor (W739083) data.
12-volt DC motor features 152 rpm and 300 oz-in. of torque.
edit -- See datasheet attached in another thread. /edit
Richard Wallace
since 2003
Last edited by Richard Wallace : 08-01-2011 at 14:39. Reason: added link to Michael Coleman post with datasheet
Unread 08-01-2011, 14:11
RandAlThor RandAlThor is offline
FRC #0115
RandAlThor is an unknown quantity at this point
How about if the minibot has another minibot that it shoots up the pole?
Or if the hostbot "kicks" the minibot up the pole?
Unread 08-01-2011, 14:39
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
That would most likely be considered a detaching mechanism and therefore illegal (as it doesn't fall under the exception of the minibot detatching from the hostbot)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
