Require assistance for imaging Classmate 2GO Netbook (2011)
After about an hour of frustration, I am seeking help with the new USB key provided for the 2010 Netbook that images it. I booted from it and it formats my HD and then fails with the error 'arithmetic exceeded 32 bits'.
I then tried the 2010 restore key and it gives me the error that claims restoreds doesn't exist! Please help! Thank you very much, William Wingler |
Re: Require assistance for imaging Classmate 2GO Netbook (2011)
IM also having trouble but i cant get even close to the progress that you are seeming to be at. How do we even start the reimage?
There should be a readme file on the memory stick that gives directions on how to boot from the stick and start the reimaging.
thanks to the both of you! Im going to try that idea right now!
When i try to put the new image on the classmate, The junk drive doesnt light up is this a problem?
Could someone please post a link to the readme.txt file that is supposed to be in the flashdrive with the new image on it?
#7
select disk 0 select volume 0 set ID=27 override exit Don't know if that helps. Imaging was a piece a cake for us. Maybe we got lucky. David Team #2829 |
#8
See if this helps:
Instructions: 1. With the Classmate powered OFF, insert the bootable USB Key into an available USB port. Do not use a USB hub, plug the Key directly into the Classmate. 2. Power on the Classmate and when you see the 2Go PC screen, repeatedly press F11 until a small window appears entitled “Please Select Boot Device”. 3. Using the cursor keys, select the USB Key. It will likely be the second item in the list, beginning with USB:xxxx. Do not select the USB:Generic device, this is not your USB Key. If two identical looking USB items show up, don’t worry. Select the first of the two. 4. Press Enter and allow the Classmate to boot from the USB Key. Be patient, it can take a minute or more for wpeinit to finish. 5. Follow the on-screen instructions Last edited by Mark McLeod : 08-01-2011 at 19:08. |
#9
Thanks! That worked for us.
#10
Ok, I've fixed one problem - the old restore disk was on a U3 drive and first set the .Bat to point to D: instead of F: (U3 adds a partition, and therefore all drives are a letter off after it.)
I liked the old rescueds system so I backed up my 2011 and used the files from 2010 and updated essentials, using the INSTALL.WIN file instead of the old version in 2010. I can format the HDD, but I still get an error trying to flash the .WIN to the drive. It's always the arithmetic error. I get to the stage where I can follow onscreen instructions fine, wpeinit runs fine. It's when actually using the image. Perhaps I have a bad image? Can anyone link me to where I can download the 2011 flash drive contents? |
#11
We succeeded in re-imaging the 2GO Netbook, but i keeps asking to to "Activate Windows"
We select "Activate now" and then "Active Windows online now" but then we get an Error Code 0x8007232B "DNS Name does not exist" When I ping the DNS IP address, though, it responds. Any ideas? Is there supposed to be a new code that we use to activate? |
#12
