Programming Minibot
Is there any language we have to use to program the minibot?
Re: Programming Minibot
I do believe reading that you could use LabView or maybe easyC? Something like that. I'm kind of concerned with this also because I have never programmed outside of FRC and general programming.
It appears that if you use the NXT controller than you will be using a simplified version of Labview. Really simplified.
David Team #2829 |
In regards to using LabView to program, this thread in the LabView section has some pretty decent discussion.
My post in that thread discusses how you could accomplish programming in LabView for FRC and FTC on the same computer: Quote:
You should be able to use any language you can use for FTC (Labview and RobotC) I believe.
I think that is why we were advised to make the acquaintance of FLL or FTC teams. They are familiar with programming the NXT for their respective seasons. Most of the FLL teams are done for the year, but I think FTC are still active. FLL teams are also harder to find.
There has been speculation about restrictions on programming language for the NXT. I will eventually scour the rules to find it. It's only needed after a climber minibot is built that needs an NXT. |
#7
My team was thinking that we were going to use just a simple PIC. Does anyone know if that is against the rules because it isn't used by FTC teams?
#8
PIC not included in allowable MINBOT parts. AFAIK ![]() |
#9
I LOVE THE NXT!!!
i have one myself. so how exactly do we program it? |
#10
Can't we just use the FLL NXT-G Mindstorm program that comes with the device? It's a really simple version of Labview
#11
There has been no word that I know of that says you have to use a certain program though I think if you use LabView it will be easier.
#12
There are a variety of languages that can be used for the NXT. It is highly recommended you find an FTC team for help. There is a "Find teams in my area" on the First website to help in your search.
#13
Why would you program the Mini-bot?
Everyone knows that code just adds excessive weight. |
#14
Can someone post a picture of how to wire your minibot so that no programming is needed? Our team is planning on using switches to turn our minibot on, but we keep blowing fuses in the battery. We're having trouble with this, so the help would be greatly appreciated!
#15
To prevent fuses from blowing up you should either use 10A fuses or fix your wiring, meaning making sure there is no metal wiring that isn't underneath the wire sheath being exposed. My FTC has blown the fuses in our wiring but since we replaced them and fixed our wiring it hasn't happened again. |
