Go to Post The gates were removed for this game so that it would be easier to get the Zamboni in and out when the field was resurfaced after each round. - dlavery [more]
Unread 10-01-2011, 07:26
Jester Jester is offline
Labview Maniac
AKA: Cody Ripley
FRC #3144 (Krypto-Knights)
Jester is an unknown quantity at this point
[2011] Mecanum Controller
I have read somewhere (can't remember) in the forums that you need a 3-axis joystick, or 2 of the Logitech Attack 2-axis joysticks. If you have any suggestions on a nice joystick or any other solutions please discuss with me.
I have found a joystick, which looks really nifty!
http://www.provantage.com/logitech-9...3~7LGTC967.htm
It has everything the Logitech Attack 2-axis joystick has, but it also has a twist handle (which I would guess is 3rd axis).
Unread 10-01-2011, 07:42
Re: [2011] Mecanum Controller
A mecanum vehicle has 3 independent degrees of freedom:
fore/aft (forward/reverse)
left/right (strafe)
and
rotate (turn, yaw)
It can perform all these motions simultaneously, resulting in motions that sometimes look like an ice skater rather than a wheeled vehicle.
To get the full capability of a mecanum, you would need to give the driver control of each of these 3 degrees of freedom. Thus, a 3-axis joystick or 2 2-axis joysticks.
Typical driver interfaces are
(3-axis joystick)
Y-axis fore/aft
X-axis strafe
Z axis rotate
(2 2-axis joysticks)
"Halo"
Y1-axis fore/aft
X1-axis strafe
X2-axis rotate
There are of course many other interfaces.
You can use the 2-axis joystick in the kit of parts, and buy another exactly like it. I believe Logitech makes a suitable 3-axis joystick.
Or you can use a single 2-axis joystick:
with trigger not pulled:
Y-axis fore/aft
X-axis strafe
with trigger pulled:
Y-axis fore/aft
X-axis rotate
The above, of course, allows only 2 degrees of freedom at a time, but may be sufficient for your purposes, depending on the game.
Unread 05-02-2011, 18:43
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
My team uses a Microsoft Sidewinder Precision 2 joystick.
I highly recommend it, because:
1. the handle is ergonomic (for the right-handed)
2. there is a good amount of resistance in all three axes
2a. the handle twist is especially smooth
3. the throttle is large and within reach
4. the buttons are well-placed
