Go to Post Just because we don't cheer, doesn't mean we don't have fun. ;) - JVN [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Unread 10-01-2011, 15:01
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Minibot climb rate
We have not received our FTC parts yet, obviously because the orders went in today . I have a couple quick questions and then a result of quick calculations based on assumptions.
What are the weights of the following items?:
NXT controller, Tetrix motor, 12v battery pack, HiTechnic motor controller.
I did some very ballpark calculations based on ideal situations. If we can build a robot weighing less than 5 Lbs, it should be able to climb the pole in less than 7 seconds.
Does that sound right?
Unread 10-01-2011, 15:05
Brandon Holley's Avatar
Re: Minibot climb rate
What are you basing your calculations on? Overall output of the motors (ie: power)?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-01-2011, 15:10
billbo911's Avatar
-Brando
Yep! I chose to run the calculations close the motor's max efficiency. I also chose to use the largest wheel I could find that appeared to be legal.
Unread 10-01-2011, 15:27
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
This calculation is actually very easy using the work-energy thorem.
Power = Work / Time
Work = weight * height
Therefore:
Time = (weight * height) / Power
Example:
Motor power: 8.43 W (Tetrix motor)
Efficiency: 0.85
Weight: 5 lb * 4.4545 N/lb = 22.27 N
Height to climb: 2.1 m
assume gearing for peak power.
then:
Time = (22.27 N * 2.1 m) / (8.43 W * 0.85)
Time = 6.53 sec
This is the FASTEST time. If you make the wheel big enough that the torque on the motor causes the motor to move away from the peak power point, the minibot will climb SLOWER, not faster. In other words, bigger wheels aren't always better.
Unread 10-01-2011, 15:40
billbo911's Avatar
Power = Work / Time
Therefore:
Example:
Efficiency: 0.85
then:
Time = 6.53 sec
I looks like your numbers and mine are spot on. I took a different approach, but the result is the same within .1 seconds.
Just so others can see where I got my numbers, I ran it through the JVN Calculator.
Unread 10-01-2011, 15:48
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Seems like everyone is forgetting the possible use of surgical tubing to shoot that bot up the pole much much faster.
Also you can use 2 TETRIX motors.
-Borna Emami
Team 0x27
Unread 10-01-2011, 15:52
billbo911's Avatar
Who says we are forgetting?
Unread 10-01-2011, 21:36
Jibs Jibs is offline
FRC #2506 (Saber Robotics)
Jibs is an unknown quantity at this point
So the calculation above is based off one motor?
Unread 11-01-2011, 01:28
TGA Reaper's Avatar
TGA Reaper TGA Reaper is offline
AKA: Kevin
TGA Reaper is an unknown quantity at this point
Question: What is the estimated ideal weight for the mini bot?
Unread 11-01-2011, 01:33
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
The first one we built was about 4 pounds. I think the final version we settle on will be more like 6-7 pounds.
Unread 11-01-2011, 01:57
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
i think my team intends to use surgical tubing to launch the mini-bot to the top in less time than 1 second. last years kicker on our robot only contacted the ball for 3 inches and was able to kick pretty far. i think we will be doing something similar for this.
Unread 11-01-2011, 10:30
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
WHAT is this obsession with using surgical tubing to launch your minibot?
You can use springs to launch it just as well if not better, they just have to be part of your main robot.
Unread 11-01-2011, 02:19
TGA Reaper's Avatar
AKA: Kevin
have you tried the heavier weight yet?
Unread 11-01-2011, 09:16
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
What are the odds that a minibot launched by a slingshot will recieve a penalty?
I feel <G20> might be at risk as the slingshot might tap it after its initial release.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 11-01-2011, 09:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Hmm, the calculations I'm getting from both of my 'drag race' calculators, adjusted for straight vertical ascent, comes out to just over 5 seconds. I'll investigate...
Please use the other minibot threads for this question...
GitHub
