Go to Post Why does 1114 have to be good at everything? ;) - Justin Montois [more]
Unread 10-01-2011, 22:55
Generator of Entropy
FRC #2973 (The Mad Rockers)
Pitsco gear dimensions
The worthless tetrix and pitsco websites have no dimensions that I can find. The 120 tooth gear "spec" tab says "120 tooth gear". Gee, really? No diametral pitch or pitch diameter, no thickness.
If anyone has an FTC gear, can they give me a thickness and the diametral pitch? Thanks.
Unread 10-01-2011, 23:50
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: Pitsco gear dimensions
I don't know the pitch of the gear but they are roughly 1/4 inch thick.
120 tooth gear is close to 4 inches in diameter
80 tooth gear is close to 3 inches in diameter
and 40 tooth gear is just over 1 inch in diameter.
Hope this helped
Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 11-01-2011, 02:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Andrew, if you've got a set of calipers, try this: take 2 more than the number of teeth, and divide by the outer diameter (measure the outside diameter across the rounded outer surfaces of two opposed teeth). For a conventional AGMA involute spur gear, this will be the diametral pitch.
(I always assumed they were 32 diametral pitch, but then again, I never had to use them for anything. They could just as well be 0.8 module, which is 31.75 diametral pitch.)
