Minibot questions
Can you or can you not have springs which are loaded during any part of the match?
If I can recall the manual says something about loaded springs but can you load them during the match? Thank you, Team #2230 |
Re: Minibot questions
If the loaded springs are meant to be on the minibot, then no. It is not allowed. However, you are allowed loaded springs on your hostbot.
can i start the match with a loaded spring? or i need to load it during the match?
can somebody answer his question?
this is an issue |
From what I can tell the rules do not specifically state that you cannot have a pre-loaded spring. But they do have a warning in there that the discretion will be up to the judge. So my guess is that a large load probably cause some problems but a very small load will not.
IN ANY CASE - ANY ANSWER YOU GET HERE IS NOT OFFICIAL!
ONLY ANSWERS FROM THE OFFICIAL Q&A FORUM SHOULD BE CONSIDERED. |
#7
Soooooo... Does anyone have a quote from the manual its self allowing or rejecting the idea |
#9
well if you were planning on using the spring to launch the minibot i wouldnt try that. That would be considered a safety hazard and is also not following the definition of deploying the minibot. using a spring to push somehting on the hostbot to push the minibot might be allowed but considering the amount of questions about this i think FIRST will be adressing this question in one of their updates.
#10
BTW: when is the next update coming out??? |
#11
From the Administration section of the manual (you know, the parts without the password that you had a week or so before Kickoff to study):
