Go to Post "What other program puts these role models on a first name basis with teenagers?" - Andy Baker [more]
Unread 11-01-2011, 12:07
C_Tenranma's Avatar
C_Tenranma C_Tenranma is offline
Programmer
AKA: Chelsea
FRC #1865 (RoboBuffs)
C_Tenranma is an unknown quantity at this point
NXT and Labview
Is there a way to extract a code from the NXT programming to use for Labview?
Unread 11-01-2011, 12:22
Re: NXT and Labview
I'm not sure I understand the question. If you asking if you can program the NXT from the FRC version of LV, the answer is technically yes, but you'll be using older VIs to do so. The new ones are a bit easier to use and are for newer versions of LV. Also, the rules may limit what you can use to program the brick. If not, then you could download the NXT toolkit and get some basics working.
Thinking about it a bit more, I don't believe you'll have tetrix motor control unless you use the newer tools.
Greg McKaskle
Unread 19-01-2011, 00:07
Carter12s's Avatar
Carter12s Carter12s is offline
FRC #2036 (Black Knights)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Re: NXT and Labview
The Lego NXT bricks can be programmed using labview and the NXT Toolkit Available here http://zone.ni.com/devzone/cda/tut/p/id/4435 .
Programing is the real way to build a robot.
