Line sensor
Is it legal to use the Line Sensor Array from MindSensors.com and hook it up to the I2C port?
http://www.mindsensors.com/index.php... &PAGE_id=111 |
Re: Line sensor
What rule do you think might prohibit it?
Re: Line sensor
Don't know. That's why I asked.
Re: Line sensor
This is going to sound harsh, but I think it's warranted. If you don't know the rules, you shouldn't be designing a robot.
Re: Line sensor
The relevant rule is <R62>, the sensor input rule. I don't see anything in there that would prohibit this, but I encourage you to look at it just to make sure I'm not missing anything.
Re: Line sensor
I did read through the rules and can't find anything indicating they are not allowed. It basically said anything COTS should be fine except for the budget rule. But I may miss some fine print and/or not interpreting the rules correctly. That's why I ask. In addition, I was also involved in FTC and FTC has strict rules on what sensors are allowed. So I just want to make sure it is allowed in FRC.
#7
Re: Line sensor
Mike,
Are you asking if it possible to connect this device to an NXT brick or are you asking if you can interface it to the CAN buss and use it for robot control? Under the Team Update #1 issued last night, this appears to be an NXT sensor so you can use it for that. As to interfacing to the CAN buss, that might be a more daunting task and the rules outlined by Eric above apply as well as other electrical rules for power and wiring size. |
#8
Re: Line sensor
No, not the CAN bus. I believe the digital sidecar of the cRIO has an I2C port that is compatible with NXT sensors. I am thinking of using that. I know another team in some previous year successfully hooked a NXT compass sensor to it. So I know it is possible. However, we may have to write some I2C code to access the sensor.
