Go to Post Moral of the story: Keep something you can power on gamepieces at all times. Leaving them "to do their own thing" will only lead to heartbreak. - Ian Curtis [more]
Unread 13-01-2011, 18:20
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Power Converter 360 CPR
Any one know how we hook this up? Is there a diagram?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 13-01-2011, 18:32
Re: Power Converter 360 CPR
The wiring is very similar to last year. It just goes inline between the PD and the robot radio's barrel connector.
12v side (it's marked on the bottom) goes to the special purpose 12v wago connector built into the end of the PD by the power status LEDs, black is ground.
The 5v side goes to a barrel connector, center positive, that fits the radio.
You can cut off the barrel connector and cord from the wall-wart that came with it, or find one.
Unread 13-01-2011, 19:44
AKA: Ledge
Thanks so much! I will pass it on to our electrical people!
Unread 13-01-2011, 23:21
The 12 volt incoming wires will fit in a Wago connector to plug into the Power Distribution Board. That's handy.
We cut the router's power cord and added a set of Anderson Powerpole connectors to both sides so we could reconnect it and still use the wall supply if we wanted to. Another Powerpole pair went on the converter's 5 volt output. We haven't tried the converter to make sure it works yet, but we'll certainly measure its output before we connect the router.
Unread 13-01-2011, 23:27
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
We got ours up and running. Seems to do the job. Also, if your students have not noticed, there are labels on the back side that should make it all pretty easy. The black wire with the white stripe for the Dlink thing is the positive (+) and the regular black wire is the negative(-).
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 14-01-2011, 00:05
AKA: Ledge
Thanks for all the info guys! I passed it all on to our electrical girls.
Unread 17-02-2011, 17:47
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
Ours only puts out 4.1 volts, not enough for the radio.
They do not supply them from the US only China. Price is reasonable.
I have a question in to FIRST about what we can substitute.
Current-Logic's P/N is TBJ12DK025Z.
Charlie Affel, 1712
Charlie Affel,
Mentor 423
Unread 17-02-2011, 20:41
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
You must use the same model of the power convertor that came in the kit, I believe if I remember the rules correctly.
Unread 18-02-2011, 12:02
AKA: Charlie Affel
FRC #0423
Yes that's the rule R38.
Everyone needs to power their radio and our converter is broken.
Some remedy is required.
Charlie Affel,
Mentor 423
Unread 18-02-2011, 13:36
RyanN's Avatar
RyanN
Order a new one for competition. If you're not using your camera, plug the Dlink into the camera's 5V power connection and use it for now. When you get to competition, unhook it, and connect the power regulator to make your robot legal.
The current supply from the 5V output on the PD board is rated for 3A, which is plenty enough to run the Dlink. The 5V output is not a boost supply, so low battery voltage, or huge current spikes can cut power to the Dlink.
I don't see any issue in doing this. Maybe some other mentors can post and tell me their thoughts.
I know this isn't a FRC legal idea, but to get the team up and running, it seems like a good temporary idea.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 18-02-2011, 13:57
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Can someone post a question to the Q&A? That way we can get an official 'fix'.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 18-02-2011, 14:54
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I believe you hit the nail on the head here. The 5V supply is only guaranteed to regulate higher voltages safely down to 5V, and not sustain it should the battery voltage sag too much. That said, it's pretty robust and will work pretty close to the 5V mark, but none the less, a sufficiently dead battery could pose problems.
FIRST has a lot going on and simply wants to eliminate debugging radios resetting from low power from all the other stuff that breaks at the most inopportune moments for the field crew The boost supply on the 12V rail helps with that, but it was previously designed for the Linksys bridge, so we need the new converter to bridge the gap between the reliable supply, and the lower voltage radio.
Matt
Matt Krass
