I feel like an idiot (Help reimaging cRio)
I accidentally reformatted a crio, and now i can't find it.
how do i influence it to work? |
Hmmm...CTRL+Z...ok, just kidding. Are you saying that you formatted it and now cannot connect to it?
Re: I feel like an idiot (Help reimaging cRio)
ok, i know where it is, but i don't know where the freaking imager program puts its image zips
So are you having trouble finding the file after you unzip it or after you download it?
i need to find where it puts the crio images so i can flash a new one
So you are having trouble finding the file after you unzip it?
#7
When you download the imager it should have the cRio image embedded in it. When you open the imager it should search for the cRio and then in the window at the bottom under "Format controller" check box it should show an image available to image the cRio
#8
The imaging program does not come with any cRIO images. Depending on what language you're using, the image is installed in different places. The image will not exist until you install the updates for your preferred language, at which time it will be placed in the appropriate folder.
