Go to Post Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. - [more]
Unread 14-01-2011, 08:38
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Answer to if the Minibot needs to stay at the top of the pole
Quoted from the Q&A Forum, originally posted by GDC:
Per the definition of TRIGGERED, once the disk sensors are tripped, the MINIBOT RACE on that TOWER is complete. Therefore, the MINIBOT does not need to stay at the top of the tower. It is encouraged that you design your MINIBOT so that it's easily retrieved at the end of the MATCH.
Actual thread found here: http://forums.usfirst.org/showthread.php?t=16121
Unread 14-01-2011, 08:52
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Answer to if the Minibot needs to stay at the top of the pole
Very nice, but something most teams assumed.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 14-01-2011, 09:09
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
I'm still curious how folks are going to remove these robots. I can just imagine someone getting hit in the head with a falling robot.
Unread 14-01-2011, 09:15
Zuelu562's Avatar
AKA: Jake Janssens
Well the incentive is for minibots to be as light as possible. We have a mentor who is very versed in the creation of 1lb bots. If we get that, as few electronics as possible, with those two motors we will FLY up the pole.
Team Resume
Volunteer Resume:
Unread 14-01-2011, 09:23
wilsonmw04's Avatar
Coach
I get the getting up part. How are you going to get it down? There is a statement that if it takes you more than a minute to remove your robot you can receive a yellow card.
Unread 14-01-2011, 09:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Minimum weight of a minibot is ~2.25 lbs due to the battery and motors. It will weigh a 1/2-lb more unless it's held together with magic, turned on by magic, and the motors drive weightless wheels. Just thought I'd throw that out there.
GitHub
Unread 14-01-2011, 09:40
Zuelu562's Avatar
AKA: Jake Janssens
That is a thing we have yet to tackle. XD We've been mainly focusing on the HOSTBOT.
We weren't really realistically looking for a 1lb bot. We are thinking crazy light, and if you don't need a control system (NXT), and just have a switch make it go, that reduces a lot of weight.
Team Resume
Volunteer Resume:
Unread 14-01-2011, 10:25
wilsonmw04's Avatar
Coach
The reality of the rules is that one motor and one battery (the minimum requirements from the rules)weigh more than 1 lbs.
Unread 14-01-2011, 10:44
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
That battery that comes with the kit is crazy heavy. I was shocked at the size and weight of all of it. We have a highly affective Lego team and we are going to bring that group in to help build the mini bot.
Unread 14-01-2011, 10:39
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
While our team hasn't started on the minibot design yet, I couldn't help think about it during a few slow work days earlier this week... It should be possible to have a minibot that turns on when it hits the tower, drives up the tower, and turns off when it gets to the top, allowing it to glide down. If that doesn't work, run the motors in reverse once you hit the top and drive down the tower.
In theory (we haven't gotten the minibot kit from FIRST Choice yet, so we can't even play with anything there), with a proper setup, this can be done (at least electronically) with the two allowed motors, a battery, and 3 switches. It might take a little creativity on a team's part to do it with such a minimal setup... but it is, in theory, possible!
Unread 14-01-2011, 11:14
GaryVoshol's Avatar
Cogito ergo arbitro
Stu's hard hat will come in handy!
(since 2004)
Unread 14-01-2011, 11:34
SAMBURGER's Avatar
SAMBURGER SAMBURGER is offline
AKA: Sam Johanson
FRC #2557 (SOTA Bots)
SAMBURGER is an unknown quantity at this point
Assuming is the factor that would be one's downfall when one goes to regionals and find out the minibot has to stay at the top, in this case it does not have to, but I was speaking hypothetically.
Team 2557, SotaBots, destroyer of worlds.
