Go to Post For guys, is the appropriate term "manpris". ? - Chris Fultz [more]
Unread 14-01-2011, 19:34
Damian2012 Damian2012 is offline
FRC #0904
Damian2012 is an unknown quantity at this point
Can't Deploy code?
When I deploy the code, it says that the main vi, is broken or not in a deployment state. Can anyone help me?
Unread 14-01-2011, 21:55
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Can't Deploy code?
I don't use LabVIEW, but could a moderator please move this into a sub-forum where any LabVIEW programmer's might be looking?
Unread 14-01-2011, 22:06
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
When you press the Run button (which is broken because it is broken) it will pop up with an Error List box. Each item in the list is something you have to fix before you can run your code. You can select one, and press Show Error and it will highlight the part it dosen't like. If it says "SubVI is not executable", that means there is an error in a different VI, and it can't run without that VI.
More details helps. What is the error? Are there any broken lines? Unwired terminals?
Kettering Motorsports
