Does any one have a working example on how to program a mecanum wheels to move side by side using LabView, please ??
Thanks!! ![]() |
Re: Mecanum wheels programming
There's a vi for that. Holonomic vi The "Y" input to the vi is for forward/reverse motion. The "X" input to the vi is for strafe right/left (sideways) motion. The "Rotation" input to the vi is for turning (yaw). To take advantage of all three possible motions, you will need to provide those 3 inputs to the vi, so you will need a 3-axis joystick or two 2-axis joysticks or some other scheme. Last edited by Ether : 16-01-2011 at 13:58. |
thanks a lot . does that works with 4 wheels that all in the same direction !! ( forward\ reverse) ??
I thought we might need 2 wheels going ( forward ) and the other 2 ( reverse ) so that it moves side by side ! |
Take a look at this thread. The "X" and "O" mentioned in the post is the visual appearance of the mecanum rollers. The wheels themselves should all be aligned parallel to the robot's fore/aft axis. Last edited by Ether : 16-01-2011 at 13:57. |
Ok I am very new, and this may be a stupid question but where is the "Holonomic vi" I can not find it and non of the team is really great with LabView yet.
Thanks Jeff |
At the bottom of the functions palette is the "WPI Robotics Library".
The first thing in the WPI Robotics Library is "RobotDrive". You'll find the Holonomic Drive vi right next to Tank Drive and Arcade Drive. Last edited by Alan Anderson : 19-01-2011 at 22:29. Reason: functions palette is not tools palette |
#7
This is what I did, correct me if I'm wrong, PLEASE! 1. Open LABVIEW 2011 2. Go up to the "tools" bar 3. ?? (Where do I find the "WPI Robotics Library"?) 4. Holonomic Drive VI 5. Profits |
#8
Thanks everyone, you all are very helpful.
#9
You can open the function palette by right-clicking on a blank spot in the block diagram, or by choosing "Functions Palette" from the View menu. |
#10
Forget my comment, I learned how to make mecanum from scratch.
