1.75 steel pipe
I have been experiencing some difficulties on locating 1.75 Steel Pipe to do some tests on where can I find some?
--Preferably a store in Minnesota or a online one to order from-- |
Re: 1.75 steel pipe
Your local building supply store should have it in stock, it's called 1.5" EMT
Re: 1.75 steel pipe
You can get it at Home Depot. It's actually 1 1/2 electrical conduit.
Re: 1.75 steel pipe
Re: 1.75 steel pipe
McMaster-Carr is an excellent resource to purchase raw metal materials. They're usually very fast.
http://www.mcmaster.com/#steel-pipe/=amdqzs |
Re: 1.75 steel pipe
Right. The nominal diameter (i.e., what they call it) is 1-1/2" EMT, but the stuff is just about 1-3/4" in diameter. Like the rules say.
#7
Re: 1.75 steel pipe
Or use top rail for chain link fence, it's the right size. Whatever you have laying around
#8
Re: 1.75 steel pipe
Thank you for the help but wont most fences have different dimensions.
#9
Re: 1.75 steel pipe
I was wondering about the surface. I have been testing on 1 3/4 DOM steel tubing. Is the game played with galvanized pipe?
#10
Re: 1.75 steel pipe
The 1.5 EMT that I bought is galvanized, which I'm pretty sure is standard finish. The OD (per spec) is actually 1.74. This is the material that the official field drawing calls out.
#11
Re: 1.75 steel pipe
It might be difficult to find these materials in different countries. |
#12
Re: 1.75 steel pipe
EMT is galvanized coated. Looking at several brands some are very smooth and uniform. Home Depot sample was rough. If I had HD tubing and my bot worked oK, I'd be worried about showing up at the comp and finding FIRST used very smooth and uniform tubing.
