TrackerDemoProject
Hello,
I was wanting to try to use the trackers on a mock up robot for this year and when ever i try to look at the Project(click on the link to it in netbeans). It always says "Message Project: C:\Users\Developer\Demos\CodeSamples\TrackerDemoPr oject not found! Any ideas i cant seem to open any of the Sample Projects. |
Re: TrackerDemoProject
The tracker demo project is for the camera
The "Line Tracker Project" is for the line trackers line tracker only has one class: /*----------------------------------------------------------------------------*/ /* Copyright (c) FIRST 2010. All Rights Reserved. */ /* Open Source Software - may be modified and shared by FRC teams. The code */ /* must be accompanied by the FIRST BSD license file in the root directory of */ /* the project. */ /*----------------------------------------------------------------------------*/ package edu.wpi.first.wpilibj.templates; import edu.wpi.first.wpilibj.DigitalInput; import edu.wpi.first.wpilibj.DriverStation; import edu.wpi.first.wpilibj.RobotDrive; import edu.wpi.first.wpilibj.SimpleRobot; import edu.wpi.first.wpilibj.Timer; /** * Sample line tracking class for FIRST 2011 Competition * Jumpers on driver station digital I/O pins select the operating mode: * The Driver Station digital input 1 select whether the code tracks the straight * line or the forked line. Driver station digital input 2 selects whether the * code takes the left or right fork. You can set these inputs using jumpers on * the USB I/O module or in the driver station I/O Configuration pane (if there * is no Digital I/O module installed. * * Since there is the fork to contend with, the code tracks the edge of the line * using a technique similar to that used with a single-sensor Lego robot. * * This code worked on a simple bot built from the 2011 kit chassis and weighted * to behave similarly to complete robot complete with scoring mechanisms. Your * own robot will likely be geared differently, the CG will be different, the * wheels may be different - so expect to tune the program for your own robot * configuration. The two places to do tuning are: * * defaultSteeringGain - this is the amount of turning correction applied * forkProfile & straightProfile - these are power profiles applied at various * times (one power setting / second of travel) as the robot moves towards * the wall. * * In addition: this program uses dead reckoning - that is it drives at various * power settings so it will slow down and stop at the end of the line. This is * highly dependent on robot weight, wheel choice, and battery voltage. It will * behave differently on a fully charged vs. partially charged battery. * * To overcome these limitations, you should investigate the use of feedback to * have power/wheel independent control of the program. Examples of feedback * include using wheel encoders to measure the distance traveled or some kind of * rangefinder to determine the distance to the wall. With these sensors installed * your program can know precisely how far from the wall it is, and set the speeds * accordingly. * */ public class LineTracker extends SimpleRobot { RobotDrive drive; // robot drive base object DigitalInput left; // digital inputs for line tracking sensors DigitalInput middle; DigitalInput right; DriverStation ds; // driver station object for getting selections double defaultSteeringGain = 0.65; // the default value for the steering gain public LineTracker() { // create the robot drive and correct for the wheel direction. Our robot // was geared such that the motor speeds needed to be inverted for // positive speeds to go forward. You may not need these. drive = new RobotDrive(1, 2); drive.setInvertedMotor(RobotDrive.MotorType.kRearL eft, true); drive.setInvertedMotor(RobotDrive.MotorType.kFront Left, true); drive.setInvertedMotor(RobotDrive.MotorType.kFront Right, true); drive.setInvertedMotor(RobotDrive.MotorType.kRearR ight, true); // set the MotorSafety expiration timer drive.setExpiration(15); // create the digital input objects to read from the sensors left = new DigitalInput(1); middle = new DigitalInput(2); right = new DigitalInput(3); // get the driver station instance to read the digital I/O pins ds = DriverStation.getInstance(); } /** * This function is called once each time the robot enters autonomous mode. */ public void autonomous() { int binaryValue; // a single binary value of the three line tracking // sensors int previousValue = 0; // the binary value from the previous loop double steeringGain; // the amount of steering correction to apply // the power profiles for the straight and forked robot path. They are // different to let the robot drive more slowly as the robot approaches // the fork on the forked line case. double forkProfile[] = {0.70, 0.70, 0.55, 0.60, 0.60, 0.50, 0.40, 0.00}; double straightProfile[] = {0.7, 0.7, 0.6, 0.6, 0.35, 0.35, 0.35, 0.0}; double powerProfile[]; // the selected power profile // set the straightLine and left-right variables depending on chosen path boolean straightLine = ds.getDigitalIn(1); powerProfile = (straightLine) ? straightProfile : forkProfile; double stopTime = (straightLine) ? 2.0 : 4.0; // when the robot should look for end boolean goLeft = !ds.getDigitalIn(2) && !straightLine; System.out.println("StraightLine: " + straightLine); System.out.println("GoingLeft: " + goLeft); boolean atCross = false; // if robot has arrived at end // time the path over the line Timer timer = new Timer(); timer.start(); timer.reset(); int oldTimeInSeconds = -1; double time; double speed, turn; // loop until robot reaches "T" at end or 8 seconds has past while ((time = timer.get()) < 8.0 && !atCross) { int timeInSeconds = (int) time; // read the sensors int leftValue = left.get() ? 1 : 0; int middleValue = middle.get() ? 1 : 0; int rightValue = right.get() ? 1 : 0; // compute the single value from the 3 sensors. Notice that the bits // for the outside sensors are flipped depending on left or right // fork. Also the sign of the steering direction is different for left/right. if (goLeft) { binaryValue = leftValue * 4 + middleValue * 2 + rightValue; steeringGain = -defaultSteeringGain; } else { binaryValue = rightValue * 4 + middleValue * 2 + leftValue; steeringGain = defaultSteeringGain; } // get the default speed and turn rate at this time speed = powerProfile[timeInSeconds]; turn = 0; // different cases for different line tracking sensor readings switch (binaryValue) { case 1: // on line edge turn = 0; break; case 7: // all sensors on (maybe at cross) if (time > stopTime) { atCross = true; speed = 0; } break; case 0: // all sensors off if (previousValue == 0 || previousValue == 1) { turn = steeringGain; } else { turn = -steeringGain; } break; default: // all other cases turn = -steeringGain; } // print current status for debugging if (binaryValue != previousValue) { System.out.println("Time: " + time + " Sensor: " + binaryValue + " speed: " + speed + " turn: " + turn + " atCross: " + atCross); } // set the robot speed and direction drive.arcadeDrive(speed, turn); if (binaryValue != 0) { previousValue = binaryValue; } oldTimeInSeconds = timeInSeconds; Timer.delay(0.01); } // Done with loop - stop the robot. Robot ought to be at the end of the line drive.arcadeDrive(0, 0); } /** * This function is called once each time the robot enters operator control. */ public void operatorControl() { // supply your own teleop code here } } |
Where by chance did you find this template?
within netbeans
new project samples frcJava note that it is NOT in project->frc java you have to go into samples |
