Go to Post Don't let the teams here be so much of an intimidation to you, but instead, an inspiration. They all had to start from the beginning, too. - Amanda Morrison [more]
Unread 17-01-2011, 11:35
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Exclamation need help with driverstation
This year, my team is scratching the classmate, and got a netbook of our own. Everything is working great for now, except that we cant fit both the dashboard and driverstation on the netbook's screen. I believe the same problem occurs on the classmate, but the "driver" account on the classmate removes the window borders and toolbars so that both applications can fit into the screen.
I have tried googling to no success (maybe im googling the wrong thing?), and I cant increase the screen resolution on the netbook anymore (1024 x 600). I think there is probably a command prompt line I could enter into the DS shortcut that would remove the border and toolbars, but I have no clue what it is, or how to find it.
So my question is, does anyone know how I can replicate the "driver" account on the classmate so that I can remove the borders and toolbars from both applications?
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 17-01-2011, 12:09
Re: need help with driverstation
Just create a new user called Driver. The driver station and dashboard software look for that user name and remove the borders automatically.
Unread 17-01-2011, 13:22
Programming Captain
AKA: Umang
Thank you SO MUCH!! I spent an hour searching up how to hide window borders, but never thought of making a new driver account. Repped.
2010
Unread 17-01-2011, 14:51
Darnax Darnax is offline
FRC #0571 (Team Paragon)
Darnax is an unknown quantity at this point
If you really want to get fancy and have the driver account bring you to the driver station instead of the desktop (like I did with my laptop) just do the following:
NOTE: This must be done on the Driver Account so it only affects it. Make sure you have a separate Administrative Account so you can still makes changes to the computer.
WARNING: I take no responsibility for any damage you do to your computer by modifying the registry. This is entirely your own choice.
1. Go to the start menu
2. Go to Accessories > Run
3. Type in regedit and click OK.
4. Once the Registry Editor is open navigate to HKEY_CURRENT_USER/Software/Microsoft/Windows NT/CurrentVersion/Winlogon
5. Create a new String Value (Right Click > New > String Value) called Shell and set its value to the location of the driver station on your hard drive. (Should be "C:\Program Files\FRC Driver Station\Driver Station.exe")
6. Log off and back on to the driver account and the computer should enter the Driver Station automatically.
Alternatively you can use the following files I wrote (on the Driver Account) to add or remove the modification (assuming your Driver Station is installed to the default location and the computer is not a 64-bit system):
Add Modification: modify.reg
Remove Modification: heal.reg
Notice: To access the desktop on a modified account for any reason just get to the task manager with ctrl-alt-delete, go to processes, file, new task, and type in explorer.exe.
Unread 18-01-2011, 12:38
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
I wish to use my notebook instead of the classmate. I couldn't find any file with instructions to do so.
I just installed LabVIEW here, and I don't have these folders "FRC Driver Station" and "FRC Dashboard" at my 'program files'
After installing LabVIEW, what else should I do in order to replace the classmate?
Thanks
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 18-01-2011, 13:22
NI Posted instructions: http://decibel.ni.com/content/thread/8794?tstart=0
Unread 05-02-2011, 12:50
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
I ve followed the steps on my minibook that you ve writtten but somehow i couldnt transform it into a usual classmate.
