Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 17-01-2011, 16:01
MEOWMEOW MEOWMEOW is offline
FRC #2443
MEOWMEOW is an unknown quantity at this point
pole diameter question
Is it true that the outer diameter of the pole is really 1 and 3 quarters of an inch
Unread 17-01-2011, 16:03
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: pole diameter question
That's close enough; the field drawing says to use 1.5 inch EMT which has an OD of 1.74 inches.
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've never seen the real pole used on an official field (most of us, at least, and those who might have, probably didn't think to bring a caliper) so it's hard to say. But that's what the rules say.
Unread 17-01-2011, 16:13
FRC #2443
Did any start building the pole yet??
Unread 17-01-2011, 16:36
Racer26 Racer26 is offline
My guess is that the pole on the official fields will be 1-3/4" x .095" steel tubing, the same stuff that most stock cars use in their roll cages.
EDIT: My Guess is wrong, however, the differences are unlikely to be THAT important. See Tristan Lall's post below for the correct stuff.
Unread 17-01-2011, 16:37
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
1208 finished its pole today. We found the correct size (1-3/4 in OD) at a steel supply company.
Unread 17-01-2011, 17:30
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The pole is Ø1.5 in nominal OD, Ø1.74 in actual OD EMT steel conduit. Wall thickness is roughly 0.06 in. McMaster-Carr will sell it to you as 7126K5 in a 10 ft length.
That's different from Ø1.75 in steel tubing or pipe (like this, this or this, for example).
If you aren't using EMT conduit, you've got the wrong stuff. For most minibots, the differences in surface finish and flexibility probably won't matter too much—but given that the real stuff is so cheap, you might as well invest in the real material just to be sure.
Unread 17-01-2011, 18:15
MrForbes's Avatar
AKA: Jim
But don't buy it from McMaster Carr. Truck freight is kind of slow and expensive. Instead, go to your local hardware store, building supply store, or electric supply store.
Unread 17-01-2011, 18:21
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I just picked one up today at a local Home Depot. 1 1/2" EMT SKU# 091111020056 $11.76.
Unread 17-01-2011, 21:29
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
I'll just use my Festivus pole
Brian K
Team 1225 Robotics Mentor
Unread 17-01-2011, 23:28
MrForbes's Avatar
AKA: Jim
Mine is aluminum....magnets don't work on it...darn
