Go to Post I've found that being outraged on behalf of others is often a misuse of energy. - Taylor [more]
Unread 17-01-2011, 18:59
Jimmy the Kidd's Avatar
Jimmy the Kidd Jimmy the Kidd is offline
Programmer, Scouter, Tactician, etc
FRC #0364 (Team Fusion)
Team Role: Tactician
Jimmy the Kidd is an unknown quantity at this point
Two questions.
1.) Is it permissible to use ball bearings in the construction of the minibot?
2.) Is it permissible to use latches that have small springs in them?
Unread 17-01-2011, 19:02
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Two questions.
Two answers.
1.) Is it listed in R92?
2.) Only if the energy in the springs comes from the batteries after deployment.
- Arizona North
Unread 17-01-2011, 19:09
Re: Two questions.
Not for vertical motion, Alex. For horizontal latching. No mention of horizontal motion in <G19>.
I don't specifically see springs in <R92>, however, surgical tubing and rubber bands do make pretty good tension springs.
Unread 17-01-2011, 19:14
Re: Two questions.
We're using the latches to attach the minibot to our main robot. It holds no function in attaching the minibot to the climbing pole.
Unread 17-01-2011, 20:53
Electrical Engineer
Rookie Year: 1995
Re: Two questions.
Jim,
If the latches are part of the hostbot, they fall under hostbot rules (COTS, etc) but if they are part of the minibot, you would have to make them from aluminum, polycarb, etc as per the minibot rules...
JMHO,
Mike
Mike Betts
As easy as 355/113...
Unread 18-01-2011, 13:03
Re: Two questions.
Originally Posted by Mike Betts View Post
Jim,
JMHO,
Mike
Thanks Mike.
