Go to Post Note to self: Go to IRI sometime. - [more]
Unread 19-01-2011, 15:34
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
pic: MMRambotics Chassis
Unread 19-01-2011, 15:35
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: pic: MMRambotics Chassis
The battery holder is very unique, but how is the battery going to be constrained in all directions? Looks sweet.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 19-01-2011, 21:55
Bochek's Avatar
AKA: Adam Bochek
There is a large velcro strap that goes around the battery to hold it in.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 23-01-2011, 00:27
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
It looks to me like if you took a hit from the front or back, the battery mount would swing considerably. I would think about stabilizing it from the bottom with another piece of extrusion. Losing a battery on the field is not fun.
Unread 24-01-2011, 23:16
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
The battery wont swing, the whole assembly you see there is welded. Plus the Velcro strap, it wont be going anywhere.
Unread 24-01-2011, 23:46
ttldomination's Avatar
Sunny
It doesn't matter if that frame is welded or Dean Kamen is on the robot holding it together. The entire thing is only supported from the top, and then the battery drops down. The torque about the two points of connection is going to be alot. The battery mount might not fail, but you will see some swing/rotating when you accelerate/decelerate.
- Sunny
1648: 2013-2014
5283: 2015
Unread 24-01-2011, 23:58
jasonpatel555 jasonpatel555 is offline
AKA: Jason Patel
jasonpatel555 is on a distinguished road
What our captain didn't mention is that the battery holder is attached to the frame on the bottom as well, by a "part" that isn't welded on. Your absolutely correct that a sizable chunk of weight like the battery needs to be well supported/constrained.
Unread 25-01-2011, 00:08
Sunny
Well then, the thing should be fairly stable.
- Sunny
1648: 2013-2014
5283: 2015
