Go to Post Have you hugged your programmer today? - Gabe [more]
Unread 20-01-2011, 11:43
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Mecanum Wheel Confusion
Hey, I am a little confused about the mecanum wheels program, specifically the difference between the Cartesian and Polar option. I am having a hard time understanding the differences between the two and why you would choose one over the other. If someone would be able to explain the differences of the two, it would be greatly appreciated.
Unread 20-01-2011, 13:15
Re: Mecanum Wheel Confusion
Both polar and cartesian varieties have a "rotation" parameter. That determines how the robot spins around its center of rotation.
The difference is in how the translational motion is specified. Cartesian control has separate X (left/right) and Y (forward/backward) parameters. Polar control uses a vector with a direction and a magnitude, saying how fast to move in the specified direction. Polar also has an optional parameter that can make the robot move in absolute field directions instead of relative to the robot's "front" side, if you implement a gyro properly.
Unread 20-01-2011, 16:10
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
We use cartesian just because its easier and it works for what we need so I suggest you use cartesian for that reason. If you really want to use polar go ahead the only advantage is that you can wire a gyro into it.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 20-01-2011, 16:55
Last year's LabVIEW had a gyro input on the Cartesian. Did they remove it in 2011? If so, anybody know why??
(I'd look it up myself but I don't have 2011 FRC LabVIEW installed here)
Unread 20-01-2011, 22:18
My mistake -- the gyro input is present in the Cartesian version, and is absent from the Polar version.
(I was going from outdated memory and hearsay. When we first used the holonomic drive vi, the gyro support had not yet been added.)
Unread 22-01-2011, 01:08
Ahh, OK thanks for the feedback. I decided to go with Cartesian just like most of the teams.
