Go to Post At a much more pragmatic level, organization is what seperates a team full people with really cool unrealized dreams and a team that is trying to figure out it's alliance picks. - phrontist [more]
Unread 20-01-2011, 17:47
TodBringer TodBringer is offline
TodBringer is an unknown quantity at this point
FRC Vision Undeclared Functions
We're having trouble locating the library housing the functions related the camera. We have included nivision.h, but we need nivision.a according to the pdf spec.
Unread 20-01-2011, 20:37
dysxqer dysxqer is offline
Web and Software
AKA: Zack Hickman
FRC #0166 (Chop Shop 166)
Team Role: Webmaster
dysxqer is an unknown quantity at this point
Re: FRC Vision Undeclared Functions
Are you sure what you need isn't located in the vision folder in WPILib?
Unread 22-01-2011, 10:49
We found a .pdf documenting how to use the camera, primarily how to stream images to the netbook. It uses functions like frcStartImageAcquisition() and frcStartPCVideoServer().
The AxisCamera.h in WPILib.h doesn't have anything to do with streaming images, so what is the header file that does?
Unread 22-01-2011, 11:14
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
To start streaming video to the classmate all you have to do is get an instance of the AxisCamera object. If you look at the implementation of AxisCamera::GetInstance() and trace the functions it calls you will see it automatically sets up a pc video server object and starts it up. Assuming you had a class named LogoVision that inherited from SimpleRobot the following code would be enough to start streaming video to your classmate once you entered autonomous mode. The api's you mentioned are at a lower level than you need to be at.
void LogoVision::Autonomous()
	AxisCamera& camera = AxisCamera::GetInstance();
	while(IsAutonomous())
