CAN on java "spazing"
Our team is using CAN and java and we are having a problem with a simple program, one that sets the jag to 1, the jag spazzes and throws a stack trace every time it stops.
I have traced it back to the CANExceptionFactory where it was talking about NIRIOEthernetTimeout or something, I do not have the code and I have to go to school now, just assume everything else is in order I think this is an issue in the wpilibs |
Re: CAN on java "spazing"
code and exception would help a lot in debugging this . . .
-Joe |
The reason I assumed it was the wpijibj was because I just got an update that made this stop working, so it was my first assumption that the only thing that had changed was the problem, but it is a new day now, I am going to reflash the cRIO and try to reinstall the 2can firmware.
Also I have not been able to use the port 2 on the cRIO after reconfiguring the 2CAN with the windows utility, but that is not the port I want to use anyway, because I like being able to view the Voltage/Temperature and all that for debugging purpouses. I will post the trace in a moment once I look over things again and make sure there is nothing wrong. |
As expected, I cannot reproduce the error, oh well it works, but I don't like it.
