Go to Post I expect you to make mistakes and need help constantly. Just be sure each time you come to me, it's a new mistake and a different kind of help you need. This way I know you're growing. - Rich Kressly [more]
Unread 21-01-2011, 23:19
darkMatt3r darkMatt3r is offline
Brah Everyday
AKA: Matt Pearring
FRC #1378 (Hilo Viking Robotics)
Team Role: Driver
darkMatt3r is an unknown quantity at this point
Line Follower Program Help
Hey all,
I've been trying to program our practice bot to follow the lines on the ground of the playing field. I've been looking at the sample code that LabVIEW supplies, but i can't quite understand how it integrates with the drive system and how I can program it to work. There are a few resources on how to program the line follower, but no clear directions.
Does anyone have a code that works and can be modified, or advice?
thanks.
-Matt
Unread 21-01-2011, 23:42
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
Re: Line Follower Program Help
I believe that the sample code is run in autonomous so make sure that you are set to autonmous when using it
Unread 21-01-2011, 23:45
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
You should also check out this document by National Instruments. It explains the line following algorithm used.
http://decibel.ni.com/content/docs/DOC-14730
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 21-01-2011, 23:48
Brah Everyday
AKA: Matt Pearring
Team Role: Driver
Haha.. thanks... that was a fail on my part
Is there anyway i can make the motors go slower during the autonomous program?
Unread 22-01-2011, 01:16
There's a control named "StraightPower" on the Autonomous Independent vi's front panel. It's an array of values, one for each second of autonomous, used when the sensors say the robot should drive straight. Change them to be what you want, then right-click and choose "Data Operations -> Make Current Value Default" to make them stick. Depending on your drivebase configuration, you should probably also change the "Y Power" array, which is used when turning.
Unread 23-01-2011, 18:14
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
I found the NI tutorial, but I must be blind; I can't find the sample code. Where is it located or what is it called? Yes, I installed the 2011 version of labview and the first update.
Nevermind. I was looking for it in examples, not in the default robot code itself.
