Go to Post ...our football team was a state champion, but i don't see -them- going to atlanta and winning there! :D - Sam Lipscomb [more]
Unread 22-01-2011, 11:37
MartinB MartinB is offline
FRC #2729 (Storm)
MartinB is an unknown quantity at this point
Holonmic VI not Working Properly Mechanum Drive
I was testing out the homonymic VI on the mechanum wheels we have and when I was telling it to strafe (I am using Cartesian mode, so that means sending a value to X) it was rotating and when I was trying to rotate, it strafed. Forward and backwards works, but the unexpected behavior is a little weird. Has there been any changes to the VI behind the scenes that would cause this? Thank you in advance for information.
Unread 22-01-2011, 19:28
Re: Holonmic VI not Working Properly Mechanum Drive
It sounds a bit like the axes from the joystick are flipped. Can you probe them, or isolate them to determine if that is the problem?
Greg McKaskle
Unread 22-01-2011, 19:30
Greg McKaskle
I think he has the vi wired incorrectly, but I don't have LabVIEW installed here so I can't check it.
See the first JPG attachment to this post.
Unread 22-01-2011, 19:53
FRC #2729 (Storm)
I blame the joystick, its wired backwards because the joystick sends a -1 when its pushed foward and a 1 when its pushed backwards. So in testing it this way by sight, fowards should have been backwards on the joystick because of these mixed signals. Thanks for your help.
Unread 23-01-2011, 07:12
It isn't the joystick, it is HID. They define forward as negative. My guess is that they were thinking airplane flight stick ... It is just a convention anyway.
Greg McKaskle
Unread 23-01-2011, 17:37
The Cartesian Mecanum Drive vi helpfully accounts for the "negative is forward" convention of a joystick.
Unread 24-01-2011, 00:47
FRC #2729 (Storm)
I wasn't paying much thought towards the motors when I was designing the diagrams to think I was switching the motors. I'll test out completely switching the true and falses when I get to test again.
Edit:
Got it working, here is a link to see the resulting change on our test bed http://www.youtube.com/watch?v=mhM_RQoiQXY
I still need to some more coding to iron out some of the problems, but I think I am doing well considering I am the only team member using labview and programming for autonomyous.
Unread 23-01-2011, 17:35
...when I was telling it to strafe (I am using Cartesian mode, so that means sending a value to X) it was rotating and when I was trying to rotate, it strafed. Forward and backwards works, but the unexpected behavior is a little weird.
This might happen if you have your left and right motors swapped at one end. make absolutely certain that what you're telling the Open Four Motor Drive matches the reality of your robot.
