Go to Post NERDs...gotta collect them all! - Conor Ryan [more]
Unread 24-01-2011, 20:05
Throwaway123 Throwaway123 is offline
FRC #3215
Throwaway123 is an unknown quantity at this point
Windriver doesn't install correctly
Each time I have installed Windriver, it never allows me to use the included FIRST modules.
In the attached photo, you can see the box that pops up when I go to File->New Project
Anybody know how to fix this?
Thanks!
Name:	corrupt installation.PNG
Unread 24-01-2011, 20:21
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Windriver doesn't install correctly
You must be running Windows 7 64-bit OS. There is a bug in Wind River that some UI dialog will show up empty in Win7 64-bit. Unfortunately, the only solution people have come up with is: run it in a 32-bit Windows or install a 32-bit Windows in a VM.
Unread 24-01-2011, 22:35
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Are you looking for the FRC code examples?
WindRiver => New => Example => VxWorks downloadable kernel module sample project => Next.
I get nine FRC examples and nine others. You can start your project with one of the FRC examples.
If there aren't any examples, you probably installed WRW with your antivirus code enabled. Uninstall WRW: Windows => Start => All Programs => WindRiver => Uninstall and Maintenance => Maintenance Tool => Uninstall.
If there are just non-FRC examples, you probably installed the C++ patch http://usfirst.org/roboticsprograms/....aspx?id=18758 => C++ Update with antivirus enabled (I've seen both these problems when antivirus is not disabled.) Disable your AV and install the patch again.
I've heard that starting a project in another manner doesn't get the #include files or $paths correct, etc. We've always started our development from one of the FRC examples, even if we had to rip out most of the example code.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
