Go to Post Make other plans. No mass-produced food at an arena is ever going to be good. - sanddrag [more]
Unread 26-01-2011, 10:03
gyro-guided skid-steer
See attachment.
It's pseudo-code for gyro-guided single 2-axis joystick control of a skid-steer robot. The robot turns and goes in the direction commanded. It's field-centric control for a non-holonomic vehicle, like a 6WD.
I'm looking for a team that would be interested in coding this up and trying it out, and collaborating with me to work out the bugs and add features, either as a learning experience or possibly for competition use.
It seems to work in a simple simulation but I don't have a good plant model of the vehicle dynamics and no access to target hardware.
Post here or PM me if interested.
Thanks.
Unread 26-01-2011, 11:05
Jared Russell's Avatar
Taking a year (mostly) off
Re: gyro-guided skid-steer
Our team has used a variant of your algorithm on several of our robots (primarily to aid in driving in a straight line...especially important the two years we had omni-wheel holonomic drives). Proportional-only control on gyro heading seemed to do a pretty decent job (way better than trying to use gyro rate as the process variable directly).
Unread 26-01-2011, 13:17
In what ways was it different? Did you guys ever write a paper or make a presentation ?
Unread 26-01-2011, 14:30
No paper or presentation (yet?). Mainly due to the fact that I was under the impression that many others had done something like it (though I can't name any robots in particular off the top of my head).
In general, our implementation only uses the gyro if we detect that the driver is trying to go straight (the X axis of single stick drive is near 0) - when turning, we leave everything up to the driver. Other than that, pretty much the same.
I would imagine you could code up similar functionality using only left and right encoders, and using the delta between each encoder rate as your error (when trying to go straight).
Unread 26-01-2011, 15:14
OK, it looks to me like that's quite a bit different from what I was trying to achieve.
What I posted is intended to make an essentially field-centric driver interface to a skid-steer vehicle: the driver "points" the joystick in a given (field-centric) direction with a given magnitude, and the robot turns and goes in that direction at the commanded speed, viz:
  • you push the joystick straight forward and the robot turns and heads straight downfield
  • you pull the joystick straight back and the robot turns around and heads back toward you
  • you push the joystick to your right and the robot turns and goes straight across the field from left to right
  • you push the joystick to your left and the robot turns and goes straight across the field from right to left
  • ... or any angle in-between
Optionally (by adding two more lines of code as shown) the robot could limit the required turning to 90 degrees or less by reversing direction. So if the robot was going straight downfield, for example, and the driver then pulled the joystick straight back, instead of turning around the robot would simply reverse direction by reversing the wheel speeds... but if the driver pushed the joystick to the right the robot would still turn and drive to the driver's right (regardless of the robot's orientation at the time).
Whether or not this mode of driver interface would be helpful depends on the game being played and the driver's experience and skill. Using this interface does not, of course, preclude having a robot-centric (or any other) interface available at the press of a button, so it could be used selectively.
Unread 26-01-2011, 20:27
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
I've been working on this for a few days now, I. would deffinately appreciate any team that could post their code to auto-orient the robot as an example code for me.
Unread 26-01-2011, 20:29
Did you look at the attachment to post #1 in this thread? Any thoughts?
Unread 26-01-2011, 20:50
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
We did this, and posted our code and a video here (under SOAD) http://thecatattack.org/DriveSystems
Watchdog.Kill();
Unread 27-01-2011, 00:32
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
We did this type of control two years ago when we did swerve drive. It worked out reasonably well, but we had some small issues with the gyro drifting a bit every once in awhile.
Our students even did it with two people: one person controlling X/Y, and the other controlling the direction the robot was 'pointing'. If it wasn't for the trailer on the back of the robot, I think it would have been pretty cool... but the two drivers ended up making it look like the bot was fighting itself.
Code is on my website if anyone's interested: http://www.virtualroadside.com/FRC
Unread 27-01-2011, 00:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We did somewhat the same in a different application: our '09 turrent used the gyro oriented with regards to the driver. It blew the judges away when they could push the joystick in a direction while we rotated the robot on our pit cart and the turrent would stay pointing in the direction the judges were commanding.
We changed the joystick x/y to a polar angle and used that and the gyro with a PID. The only major difference was that we ignored magnitude.
Unread 29-01-2011, 10:36
See attachment.
Thanks.
I made some corrections and additions, added a lot more explanation, and posted it here.
I'm still looking for a team that would like to collaborate with me on developing and testing this.
