Go to Post Andy Baker is so awsome, that his presence alone at the competition caused the scoring system to crash....multiple times...at all 8 regionals. - Andy Grady [more]
Unread 26-01-2011, 13:50
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Debugging on the cRIO
Hi everyone,
I had a question about running code on the cRIO right from the windriver interface. Say I run some code on the cRIO using right click run on target (that is probably not verbatim since I don't have windriver on here but it should be pretty correct) can I kill some tasks and be able to do it again without having to reset the cRIO?
Thanks,
Oliver
Unread 26-01-2011, 14:15
kwojcik kwojcik is offline
kwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to behold
Re: Debugging on the cRIO
I figured out how to do this 2 years ago but I highly recommend you do not try to do this. Reason being: one time we deleted the tasks and the robot started driving full speed... very dangerous.
Unread 27-01-2011, 10:34
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Really? I don't think this can happen due to the interface between the PPC and the FPGA - if the kernel crashes, the FPGA should disable the outputs.
Unread 27-01-2011, 10:42
If the DS is still sending packets to the robot, then the system watchdog is happy and fed and will keep the FPGA alive. You can use the DS to disable or estop.
The user watchdog needs to be enabled in order for a breakpoint to stop the robot. The safety features of 2011 are equivalent to having the watchdog enabled, but will only stop a specific output.
Greg McKaskle
