Minibot Deployment
Alright, so we have been brainstroming on the actrual minibot deployment method for a couple of hours now. We have several "good" ideas, however, none seems to have it all. I understand that there's usually a trade-off, but not a single design pops out. any ideas?
Re: Minibot Deployment
in reality several teams are just gonna keep it simple using just drawer slides to push it out because its not so much of the deployment that matters but the speed of the minibot to reach the top =]
I disagree. If you have 4 minibots on the field that have similar speeds, deployment could very well make the difference.
ESP |
I said that we all have the same power source and motor(s). Eagle covered it.
#8
<G19> has drastically changed some things. Deployment will give the advantage. Also the mass and friction against surface area will have to be at perfect set amounts to achieve the fastest minibot. back to the drawing board.
#9
I see a lot of people saying G19 has changed a bunch. What has changed I mean they have clarified a bit. I think a combo of accuracy and speed and you will be fine. NO??
#10
yeah the world will continue to rotate...
#11
OP: Our team has been brain-storming too, I think one of the fastest ways is with a piston to push the minibot out. The trick is releasing it from the piston, which we haven't figured out yet ![]() |
