Hi everyone,
Our team has just realised something, we don't know how to upload code with Java! This is our first year with Java and we have Netbeans 6.9.1. Thanks in advance! |
Re: How do I upload code to the Robot with Java?
First question: have you reimaged the cRio to accept Java?
Assuming you have sorted that out it's pretty simple. You connect your computer to the cRio with a crossover cable, and then in Netbeans hit "Run". The actual routines to copy it over to the bot are handled by Netbeans. |
Hi,
In the ideal world, the steps to download Java are: 1) Reimage the cRIO with the Java specific image. 2) Update Netbeans with the FRC plugins. 3) In Netbeans, in Tools>Options>Misc>FRC Configuration, update the Team Number. 4) Hit Run and cross your fingers ![]() I assume all your networking is up and running properly (i.e., you should be able to ping the cRIO). You can find more detailed information at How to Build and Load Programming in LabVIEW, C++, and Java Hope that helps! ![]() |
Our team is having the same issue,
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: PWM channel 3 on module 4 is already allocated [cRIO] at edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:112) [cRIO] at edu.wpi.first.wpilibj.PWM.<init>(PWM.java:141) [cRIO] at edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:33) [cRIO] at edu.wpi.first.wpilibj.Jaguar.<init>(Jaguar.java:41) [cRIO] at edu.wpi.first.wpilibj.RobotDrive.<init>(RobotDrive.java:110) [cRIO] at edu.wpi.first.wpilibj.templates.Team2745Robot.<init>(Team2745Robot.java:27) [cRIO] in virtual method #11 of com.sun.squawk.Klass(bci=53) [cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(99) [cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25) [cRIO] at com.sun.squawk.Isolate.run(1506) [cRIO] at java.lang.Thread.run(231) [cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42) [cRIO] in static method #3 of com.sun.squawk.VM(bci=6) |
code plz?
#7
new PWM(3); |
#8
Here are all of our declarations:
public Joystick leftStick = new Joystick(1);
public Joystick rightStick = new Joystick(2);
public Jaguar jagFrontLeft = new Jaguar(1);
public Jaguar jagFrontRight = new Jaguar(2);
public Jaguar jagBackLeft = new Jaguar(3);
public Jaguar jagBackRight = new Jaguar(4);
public RobotDrive driveRobot = new RobotDrive(1, 3, 2, 4);
public Gyro roboGyro = new Gyro(7);
double leftX =0;
double leftY =0;
double rotationRate =0;
double gyroAngle =0;
int i = 0;
#9
public Joystick leftStick = new Joystick(1); public Joystick rightStick = new Joystick(2); /* Here, the cRIO allocates slot 1-4 of the PWM. Which means if you try to allocate them again in another part of the code, you'll get errors. */ public Jaguar jagFrontLeft = new Jaguar(1); public Jaguar jagFrontRight = new Jaguar(2); public Jaguar jagBackLeft = new Jaguar(3); public Jaguar jagBackRight = new Jaguar(4); /* See? Here, you're allocating the EXACT SAME PWM slots AGAIN. Which creates problems and are most likely the cause of your problem. */ public RobotDrive driveRobot = new RobotDrive(1, 3, 2, 4); Code:
Joystick leftStick = new Joystick(1); Joystick rightStick = new Joystick(2); /* Code removed because it creates problems */ // Jaguar jagFrontLeft = new Jaguar(1); // Jaguar jagFrontRight = new Jaguar(2); // Jaguar jagBackLeft = new Jaguar(3); // Jaguar jagBackRight = new Jaguar(4); RobotDrive driveRobot = new RobotDrive(1, 3, 2, 4); Gyro roboGyro = new Gyro(7); double leftX =0; double leftY =0; double rotationRate =0; double gyroAngle =0; int i = 0; ![]() |
#10
Ahh, noob mistake. Haven't touched java in forevers. Thanks All.
#11
If I'm reading that right look at line 27 in Team2745.java. Or post the first 27 lines of that class so we can take a look at it.
#12
kk, in your declarations most of that doesn't need to be public. Try:
Joystick leftStick = new Joystick(1); Joystick rightStick = new Joystick(2); Jaguar jagFrontLeft = new Jaguar(1); Jaguar jagFrontRight = new Jaguar(2); Jaguar jagBackLeft = new Jaguar(3); Jaguar jagBackRight = new Jaguar(4); RobotDrive driveRobot = new RobotDrive(1, 3, 2, 4); Gyro roboGyro = new Gyro(7); double leftX =0; double leftY =0; double rotationRate =0; double gyroAngle =0; int i = 0; Code:
package edu.wpi.first.wpilibj.templates;
* @author William Dell
* @author Team 647
* @version v7, January 29, 2011
* @version FRC Java version 2011.4
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.Victor;
// import edu.wpi.first.wpilibj.Jaguar; // for change to production bot
import edu.wpi.first.wpilibj.RobotDrive;
public class Main extends SimpleRobot {
DStation station; // consolidated, simplified dash and driver station
Joystick controllerOne = new Joystick(1);
Timer timer = new Timer(); // one timer to rule them all....
Gyro spinGyro = new Gyro(1);
Kamera cam; // consolidated web cam controller
//------------Drive System-----------------//
Victor leftFrontVictor = new Victor(1);
Victor rightFrontVictor = new Victor(2);
RobotDrive drive = new RobotDrive(leftFrontVictor, rightFrontVictor);
/* 4 motor drive for production bot commented out here
Jaguar leftFrontJaguar = new Jaguar(1);
Jaguar leftRearJaguar = new Jaguar(2);
Jaguar rightFrontJaguar = new Jaguar(3);
Jaguar rightRearJaguar = new Jaguar(4);
RobotDrive drive = new RobotDrive(leftFrontJaguar, leftRearJaguar,
rightFrontJaguar, rightRearJaguar);
AutoDrive autodrive; // simple autonomous routines
* This method is called once when the robot boots up.
public void robotInit() {
RobotDrive driveRobot = new RobotDrive(jagFrontLeft,jagBackLeft,jagFrontRight,jagBackRight); |
#13
