Go to Post To quote Dylan, "When you aint got nothing, you got nothing to lose". - KenWittlief [more]
Unread 29-01-2011, 15:52
team3607 team3607 is offline
FRC #3607
team3607 is an unknown quantity at this point
Dlink Fried
So our team accidently fried our dlink. Are we able to use a linksys router or any other wireless adapter instead?
Unread 29-01-2011, 16:07
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
Re: Dlink Fried
Well i dont know, i would read the handbook and see. I think your best bet is to go buy another one, i think there around $70 on newegg.
Unread 29-01-2011, 16:11
FRC #3607
Re: Dlink Fried
thanks. yeah we just checked, it has to be a dlink. oh well, yeah we need a new one. they are $72 on amazon.
Unread 01-02-2011, 06:05
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Dlink Fried
For competition purposes, yes, it must be the exact same part. In the meantime you can likely get just about any wireless router to work, although the exact configuration steps required will be up to you. A better option for testing and limited driving is probably to invest in a long tether till you can get a new router.
Dare I ask how you fried it? I'd be a little surprised if connecting it directly to 12v accidentally could fry it. Was it connected to the power converter, and have you verified that it is operating correctly?
Unread 01-02-2011, 08:53
Re: Dlink Fried
Connecting it to 12 volts will damage the DAP-1522 and it is not reverse polarity protected as several teams have reported here. Be sure the power is wired correctly before inserting the power connector.
Unread 03-02-2011, 17:50
Livesmrf's Avatar
Livesmrf Livesmrf is offline
AKA: Scott
FRC #1764 (Dirty Gears)
Livesmrf is an unknown quantity at this point
Re: Dlink Fried
I am kind-of new to using a different AP/bridge and don't want to mess anything up since its not mine and all that jazz, so I am wondering where you connect the 5V AP/Bridge on the power distribution.
With new news... Apparently we need a converter. Any suggestions?
My Life
My Mind
It all makes me.
Unread 03-02-2011, 21:48
Re: Dlink Fried
Originally Posted by Livesmrf View Post
...I am wondering where you connect the 5V AP/Bridge on the power distribution.
Use the Kit of Parts web page.
Under the Control System section you will find the Robot Power Distribution Diagram document.
Unread 04-02-2011, 13:21
Livesmrf's Avatar
AKA: Scott
Re: Dlink Fried
Slightly a redundant statement as the diagram blatantly states CONVERTER. In the kit of parts, a converter was not supplied (to my knowledge).
So once again is there any ideas on what to get to dim the 12v to 5v while supplying the correct amperage?
My Life
My Mind
It all makes me.
Unread 04-02-2011, 13:52
Re: Dlink Fried
Look again.
You will find the power converter listed as the second item on Page 11 of the Kit of Parts Checklist. It was packaged in a small white cardboard box in the black tote. There is a helpful wiring diagram on the back of the converter.
We installed a Wago connector on the +12 input wires; it plugs directly into the dedicated regulated 12 volt output of the Power Distribution. We also installed a pair of Anderson PowerPole connectors on the +5 output wires, to match the connectors we put in line on the D-Link's power wire. That lets us use the wall adapter if we want to.
Unread 07-02-2011, 00:53
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Dlink Fried
Look again.
That's exactly what I am planning to do. great minds think alike
I'm going to put the Powerpoles at right angles so they can't be accidently plugged into a 12v circuit.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 07-02-2011, 07:42
Re: Dlink Fried
Great idea! This is another reason, Powerpoles are such a great product.
Unread 07-02-2011, 09:57
Re: Dlink Fried
We tried that. The two connector housings won't mesh together right on both pieces of wire. The supply side needs to twist one way, and the load side needs to twist the other. Our "solution" is to use white housings for +5 instead of red.
It's also possible, with sufficient discipline, to always enforce something like the "red on the right" rule for +12 and violate it for +5. You'd still be able to physically plug them together, but the colors wouldn't match up if you tried.
Re: Dlink Fried
It's on Page 11 of the KOP checklist "Power Converter 360 CPR"
Unread 04-02-2011, 15:47
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Re: Dlink Fried
My team has used the 5V output on the PDB and it worked just fine. We were using the power for last yrs router before we got this yrs power set up.
However, this is NOT legal in competition. My understanding is that you have to go through the power converter...but it works fine for testing.
Unread 04-02-2011, 16:02
Re: Dlink Fried
The reason it's not legal is that the 5v camera output isn't up-regulated. Your router would lose power when the battery voltage sags below seven volts or so, which it will do under heavy load. The dedicated 12v output stays there even with the battery input down to about three volts. The cRIO will disable all the robot outputs when it sees the battery voltage that low, but you won't lose communication.
