Go to Post When someone asks me to define Gracious Professionalism, I'm just going to send them to AndyMark. - rsisk [more]
Unread 30-01-2011, 00:57
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Question Analog voltage
Could someone confirm that the analog input is 0-5v?
Expect the best, Prepare for the worst
Unread 30-01-2011, 02:02
Re: Analog voltage
On the cRIO?
It is -10V to +10V input and a 5V power supply.
Unread 30-01-2011, 13:32
AKA: Jon
Re: Analog voltage
So I'm going to need a 0-10v input?
Unread 30-01-2011, 13:35
Re: Analog voltage
Nope. You can use anything that fits within -10 to +10, including 0 to 5
Unread 30-01-2011, 13:41
AKA: Jon
Re: Analog voltage
I've never use an analog sensor before what am going to get out of the vi?
Unread 30-01-2011, 14:06
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Analog voltage
I suggest you start here: http://decibel.ni.com/content/docs/DOC-14724
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 30-01-2011, 16:45
AKA: Jon
Re: Analog voltage
I know how to wire/program gyros, accelerometers, and encoders.
i was asking about analog inputs they dont have pre-written VIs for
Unread 30-01-2011, 18:19
Re: Analog voltage
There's a complete set of them.
WPI Robotics Library >> IO >> AnalogChannel
The Analog Get Voltage function is probably the one you'll be using. As the name implies, it returns the voltage present on the Analog Input pin.
Unread 30-01-2011, 18:27
AKA: Jon
Re: Analog voltage
Alright, i can work with that. thank you all!
