Go to Post I will follow FIRST's guidelines, as long as they conform with those of the English language. - artdutra04 [more]
Unread 31-01-2011, 03:21
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re-using past hardwear
from the rules i gleaned that if a team wants to use software from prior to the build season, they must make it accessible to all teams. if a team wants to pre fabricated hard-wear can we do the same thing? if we Post CAD files and a while paper to CD can we use a design that is identical or almost entirely gleaned off a prior robot?
the reason that i ask is that between 2006,2007,2008 and this year we have been refining a lift design, the new version is nearly identical to its prior versions.
Unread 31-01-2011, 05:37
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Re-using past hardwear
There's a Q&A clarification on re-manufacturing hardware from prior designs.
In the Game manual glossary, you'll find COTS hardware must be readily available to teams from a vendor. Detailed designs in professional publications can be used as "raw material" in the build season, with parts fabricated only after kickoff. The legality of using prior-year designs depends where the detailed designs are posted. There's a big difference from having drawings on a team's website vs a FIRST-wide shared library (i.e. SolidWorks, Inventor, etc.).
Please carefully read the blue box under <R22> regarding pre-fabricated and build-to-print parts. Detailed designs need to be produced during the build season.
FIRST allows software to become "COTS" if it is made available via sites widely-accessible to FRC teams. This differs from the rules for hardware.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 31-01-2011, 08:47
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Emphasis mine.
If it's "nearly" identical then that means that you've taken a previous design and modified it to fit this years needs. According to my understanding of the rule this is perfectly legal.
Then again, I'm not Q&A, so you may want to ask there.
-Dustin Benedict
