Go to Post "What we really need to make sure we do is make our robot move." - Barngirl425 [more]
Unread 03-02-2011, 15:53
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Potentiometer code
I was wondering if anyone can tell me if this code works.
v
Uploaded with ImageShack.us
Unread 03-02-2011, 15:56
FRC #2905
Re: Potentiometer code
Victors are connected to window motors.
And window motors controls the arm.
Angle(min) = 30 degrees.
Angle(max) = 120 degrees.
Unread 03-02-2011, 18:09
It won't work, although your angles are calculated correctly.
The setpoint input (the desired position) must be is the same units as the process variable (the current position).
The potentiometer is in volts: 0-5v
You can either convert the pot voltage to match your angle range, or change your angles to be the pot voltage range.
The pot voltage min/max range will have to be measured by moving the arm to it's minimum/maximum position and reading the pot value through the LabVIEW front panel or a LV probe.
Unread 04-02-2011, 03:31
FRC #2905
Thumbs up Re: Potentiometer code
Thank you really much Mark !!!!
Unread 04-02-2011, 08:29
Originally Posted by Mark McLeod View Post
]The pot voltage min/max range will have to be measured by moving the arm to it's minimum/maximum position and reading the pot value through the LabVIEW front panel or a LV probe.
Or you could just measure it with a voltmeter.
Unread 04-02-2011, 10:05
That's the answer in the Electrical sub-forum.
LabVIEW means we don't need multi-meters.
Unread 04-02-2011, 10:42
Back after 4 years off
FRC #5279
I attached a VI I wrote to handle scaling of analog inputs, it assumes your Potentiometer has a linear taper (some have log tapers) Min and Max voltage are the voltages at the min and max angles, not necessarially 0v and 5v
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
