Go to Post A chop saw may cut aluminum, a knife can also be used to eat ice cream. - fox46 [more]
Unread 03-02-2011, 20:06
jacobs1232 jacobs1232 is offline
AKA: Tess
FRC #1351 (TKO "1351")
Team Role: Student
jacobs1232 is an unknown quantity at this point
Exclamation Is my cRIO completely broken!?
After several successful years with our cRIO, we cannot establish a simple direct Ethernet connection from our programming computer to our cRIO. The Ethernet ports on the cRIO are not lighting up anymore, and we cannot ping 10.13.51.2 from any computer with a direct connection or through the bridge. Our Robot Signal Light never turns on. We have tried booting into safe mode with no results. We cannot reimage the cRIO because we cannot establish any kind of connection. Can anyone help us?
Unread 03-02-2011, 21:20
idunno42's Avatar
idunno42 idunno42 is offline
FRC #0069
idunno42 is an unknown quantity at this point
Re: Is my cRIO completely broken!?
I think it should be 10.13.51.4 but I am not so sure.
Unread 03-02-2011, 21:27
Is the power LED on the cRIO on?
Unread 03-02-2011, 22:19
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
Have you tried sticking a Ethernet cord from port 1 from the crio to a laptop?
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Unread 03-02-2011, 22:23
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Open it up and vacuum up all the foreign debris that has probably fallen in to the housing through the various port openings.
I've seen similar symptoms on a cRIO, and all it needed was a good cleaning .
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 04-02-2011, 08:47
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Check to make sure you have 24 volts at the cRIO power input. If you do, and no power light is on, call our application engineers at 866-511-6285. They will have you test a few things. If the cRIO fuse is blown, and we need to RMA the unit, we will send you a replacement immediately.
Doug Norman
Unread 04-02-2011, 18:45
AKA: Tess
Team Role: Student
We tried ping 10.13.51.4 and we got Reply from 10.13.51.9: Destination Host Unreachable.
The power LED on the cRIO is not on, and we have tried using an Ethernet cable to go directly from port 1 to the laptop.
Unread 04-02-2011, 20:34
Aluminum chaff does have a way of going where you wish it didn't, but as Doug mentioned, please verify the power inputs to the cRIO. I myself have personally carted a new cRIO to DC in my suit case only to discover that is was a bad power connection and the cRIO was fine.
If it doesn't respond to a 24V input, call NI support.
Greg McKaskle
Unread 05-02-2011, 05:25
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Greg McKaskle
Greg,
Just to take time out and say thank you NI. NI has amazing customer support, they are very direct and helpful. I sincerely appreciate all your time and appreciate your dedication to FIRST Robotics.
Tess, I highly recommend just giving NI a call.
-RC
R.C.
MadTown Robotics Team 1323
Unread 05-02-2011, 08:55
It's our pleasure.
Greg McKaskle
