Go to Post I don't see why this is an issue. Robots are immune to the N1H1 virus. - JesseK [more]
Unread 04-02-2011, 13:42
warfaj's Avatar
warfaj warfaj is offline
FRC #0610
warfaj has a spectacular aura aboutwarfaj has a spectacular aura about
Cannot find CANTimeout Exception
I've recently been having some trouble with Netbeans. I have been trying to compile this one program with no avail. Each time I get the error
cannot find symbol
symbol: CANTimeoutException
I have installed the latest frc plugins and I am running Netbeans 6.91. I have imported the class but all I receive in return is an error.
Any information would be helpful.
Thanks in advance.
Unread 05-02-2011, 09:32
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Cannot find CANTimeout Exception
Try rebooting the robot. We've also had this problem, and we've found that simply rebooting the robot generally rectifies it, though we've yet to pinpoint any source for this problem,.
Unread 07-02-2011, 17:53
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Make sure you also have the can class imported. Either of the following will work:
import  edu.wpi.first.wpilibj.can.CANTimeoutException;
//or
import edu.wpi.first.wpilibj.can.*;
A nifty shortcut is ctrl+shift+i which is fix imports. It is the first thing I try when I see a red line and I know the syntax is right.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
