Go to Post The most important part of successfully solving the problem is to understand what the problem is. Elegance in engineering comes from "optimizing" your solution, not solving problems that don't really exist. Fulfill your requirements, meet your goals... - JVN [more]
Unread 05-02-2011, 15:41
mrmatheou mrmatheou is offline
mrmatheou is an unknown quantity at this point
Pneumatics Question
Hi,
I'm a team mentor for team 2603 and we have one of our Pneumatics experts proposing an idea and wanted to make sure it was legal. Here are his comments below with a diagram explaining. Any feedback on it's feasibility would be greatly appreciated!
Here is what I am proposing.
Control of a pneumatic cylinder:
Use a 4 way 2 Position single solenoid valve for directional control of an air cylinder. At each port on the cylinder use a blocking single solenoid valve would be used to turn air on or off. The default of this valve would be passing so that when the robot is in E-stop no air is trapped. The use of these multiple valves to control a cylinder would be done in series. (Thus the flow of .3 Cv would not be exceeded)
Unread 05-02-2011, 15:46
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Pneumatics Question
I'm having a hard time understanding the need for a third solenoid.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 05-02-2011, 17:24
DonRotolo's Avatar
Back to humble
FRC #0832
I am speculating that the intent is to control the cylinder's piston so it stops in places other than the end stops.
If so, then you can get a single 3-way valve to do this, very much simplifying the setup.
What is shown appears legal to me.
But, from personal experience, trying to do this with pneumatics will be disappointing. Precision is difficult, and if the load changes the position changes as well. Search Chief Delphi for several dozen threads in the past 6 years on this topic.
Unread 05-02-2011, 18:07
It doesn't appear legal this year.
<R74> Each commanded motion of a pneumatic cylinder or rotary actuator must be accomplished via the flow of compressed air through only one approved pneumatic valve. Plumbing the outputs from multiple valves together into the same input on a pneumatic cylinder is prohibited.
Unread 05-02-2011, 21:07
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I believe it would be legal. There is only one solenoid connected to the input on the cylinder. The fist solenoid is connected to the input of the second solenoid.
My belief is that the intent of R74 it to limit a team having multiple solenoids feeding directly into one cylinder inlet, which woud significantly increase the flow rate into the cylinder.
IF you choose to go with this, it would be worth a question to the GDC.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
