Go to Post "Magnificent" is the only appropriate adjective for a handlebar moustache. Kudos. - Lil' Lavery [more]
Unread 05-02-2011, 16:01
dwmcc dwmcc is offline
FRC #2192 (YAK Attack)
dwmcc is an unknown quantity at this point
Question NEW Jaguar Problems - 2010 Jags Allowed?
We're using the 2011 Black Jaguars for our robot, connected to the digital sidecar via PWM, and as soon as we enable tele-operated mode on the driver station, we get a long flashing red light on the Jags. In the manual, it says that it's a fault condition, which could mean:
-Power supply under-voltage -- Voltage is fine, and has been double checked.
-Over temperature -- Robot has been left off for overnight, can't be the problem.
-Over current -- Current is fine as well, checked.
-Limit switch activated in the current direction of motion -- Limit switched not activated, jumpers inserted, since we're not using the limit switches.
Any help is much appreciated.
Dylan McCarthy (dwmcc)
Team 2192
www.nhs2192.tk
Unread 06-02-2011, 13:17
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: NEW Jaguar Problems - 2010 Jags Allowed?
And your limit switches are vertical, as shown in this photo?
Where and how did you measure the current?
What happens if you disconnect the motors?
-- Marshal Horn
