Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
Unread 06-02-2011, 14:55
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Question Main vi.
I know that this is the framework for your robot code. But are you able to deploy it with out editing it and be able to drive your robot around
Team 3216
Unread 06-02-2011, 15:46
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Re: Main vi.
When you start a new FRC project in LabView select the option for "Robot Framework with Game Code". This will give you the basic code to do Line Following in Autonomous, acquire camera image, and most importantly, it is setup to do Arcade control in Tele-op. So with a Joystick on USB 1 and motors hooked to PWM outputs one and two, you can control a robot right out of the box.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 06-02-2011, 16:28
Slothbron's Avatar
AKA: Nathan
Re: Main vi.
We just tried to run with it but errors just came up with the left and right motors, any ideas on how to fix it? Then how do I edit it with other vi. that have have made else where?
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 06-02-2011, 17:34
MotorHead's Avatar
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Re: Main vi.
Can you post a screen capture of what you are trying to do?
Jeff Beltramo
Team #1922
Unread 07-02-2011, 02:47
Acarid Acarid is offline
<3 Nested Clusters
FRC #2521
Acarid is an unknown quantity at this point
Re: Main vi.
You probably have the motors configured to the wrong PWM. Open up the begin vi and check that the "left and right motors" are set to the right PWMs.
