Go to Post when things start to get a little stressful, "FIRST: Fun Is Required. So Tolerate!" - Rich Kressly [more]
Unread 09-02-2011, 15:52
BrandonQ BrandonQ is offline
FRC #3171
BrandonQ is an unknown quantity at this point
Minibot (Tetrix) Questions
A few questions about the minibot, created with mostly tetrix parts...
1. The "mini-kit" we're using at the moment doesn't have much in terms of controllability. It seems that we have two motors, one on-off switch, a battery, and nothing else. How are teams controlling these things?
2. Even though plexiglass isn't polycarbonate, it's not allowed as a substitute, I assume
3. Are springs allowed on the minibot? The rules don't say anything about them, but we -are- allowed to use rubber bands and surgical tubing.
4. Are we allowed to use any other electronic components, such as resistors and relays?
Thanks for the help
Unread 09-02-2011, 15:55
Re: Minibot (Tetrix) Questions
Correct on plexiglass (acrylic) not being allowed for polycarb.
Springs are not allowed on the Minibot, because anything not specifically permitted is prohibited (first line of <R92>).
Unread 09-02-2011, 16:12
Chris is me's Avatar
AKA: Pinecone
Since the robots must be completely autonomus, we are just having a switch trigger as the minibot is deployed, powering the motors.
Acrylic is not allowed. Also, it would quickly break anyway.
The rules prohibit anything not on the whitelist of allowed parts. You are also not allowed to use stored energy to vertically climb the pole, other than through the battery (e.g. the minibot must climb using the tetrix motors)
Unread 09-02-2011, 16:45
FRC #3171
Ah, we wanted to use the springs for a small gripper, but now I see that they're not allowed (Replace with surgical tubing, maybe)
Also, since limit switches are allowed, are there "permanent" limit switches (That remain off after they flip off, for when the robot hits the top)? As far as I know (Which isn't much), they are only temporary.
Unread 09-02-2011, 16:50
Jared Russell's Avatar
Taking a year (mostly) off
You are allowed to use up to two household light switches in addition to limit switches.
Unread 09-02-2011, 18:17
FRC #3171
One more question...
For speed, what would the best gear ratio for an indirect drive?
Unread 09-02-2011, 18:24
FRC #3171
Unread 09-02-2011, 19:30
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
It depends on wheel diameter and whether or not you left the gearhead on or not.
Unread 09-02-2011, 19:50
LV1601's Avatar
LV1601 LV1601 is offline
FRC #1601
LV1601 is an unknown quantity at this point
Can we change the battery out I found a 12v 3000mah NIMH battery that is lighter weight
Unread 09-02-2011, 19:54
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
NO!
you must use the kit battery or an identical tetrix battery. no exceptions.
please read the manual. it has the answer to your question directly stated.
Unread 10-02-2011, 11:31
FRC #3171
Question: does anyone know if any DPDT "household light" switches exist, and if they can be used? Or do they all have to be the "standard" SPDT? (I know that we can also just attach two SPDT's together)
Unread 10-02-2011, 12:29
Brandon,
I have seen them but they are not generally on the shelf since the demand is so low.
Unread 10-02-2011, 12:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
You can buy them, but they're expensive. Try this or this, or search the internet for "DPDT Decora" (which is a line of wall switches made by Leviton and copied extensively).
If it's a light switch meant to be installed in a household wiring box, it's fine. (This could lead to some interesting designs using non-North-American switch types.)
Unread 10-02-2011, 19:58
SushiKitten's Avatar
SushiKitten SushiKitten is offline
FRC #1991
Team Role: Tactician
SushiKitten is an unknown quantity at this point
On the topic of house switches does anybody know if we can disassemble the switch. As far as I know that is still allowed but I just want to make sure. also if someone could tell em how to find a Q & A forum or something of the sort so I can direct my questions there next time. Thanks.
Unread 11-02-2011, 12:10
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
They should be in any decent hardware store but you'll need to look for one marked "4-way" switch. They are specifically noted in the current manual revision so yes they are legal.
