Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 09-02-2011, 18:41
Joseph W. Horth Joseph W. Horth is offline
FRC #0280
Joseph W. Horth is an unknown quantity at this point
Encoder
Is there a way to take the measurements from an encoder and turn it into a rotation and make the motor move to a specfic point based on measurement. For example I hit button 1 on Joystick Two, it tells the encoder to move the motor to that set position. Before anyone says look at the example I have, several times trying to get what I need out of it and it doesn't help for what I'm trying to do.
Unread 09-02-2011, 21:46
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Encoder
Use PID (i learned how to do it from Wikipedia). LabView has its own PID VI so before you go all crazy with code use that. Process variable is your encoder and setpoint is where you want your encoder to go to.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
