Line Sensor Yellow vs. Orange?
For line sensor, my mentor (programming) said that Yellow means receiving no signal, and Orange means receiving signal is powerful.
And when we tried the line sensor, it showed Yellow and Orange at the same time... What does that mean? Thanks ![]() |
Re: Line Sensor Yellow vs. Orange?
anything not green means its on a line, idk what the orange means
Yellow means it sees the line. Orange means its receiving 2.5 times the signal required to activiate. Idieally, you want both yellow and orange. If you just have yellow, it will work.
What about green?
are they solid lights on the sensors?
we found that we had 2 sensors working perfectly and then went for the 3rd sensor and found out we had plugged it into the wrong port. try checking your wiring to make sure you have it wired right, it should alternate between the 3 i believe... |
And I'm sure I wired it right... It's just I don't understand what's going on with color signs and the color that the sensor is detecting.. |
#7
Green means that the line sensors are getting less than the required signal required to activate.
#8
that means green is not detecting the line?
#9
Green: no line detected
Yellow: line is detected Orange: line detection is POWERFUL. yeh. ![]() |
#10
WHAT?! that's not same as what my mentor said... how did you know it??
#11
I've heard the same thing echoed around the forums, and it seems to be true for my testing. What did your mentor hear, and where did he hear it?
#12
she said that green is detecting, yellow is not and orange is receiving powerful signal.... and i guess it was from internet because she was looking at her laptop.... |
#13
According to the documentation (click here for documentation):
I'd suggest checking that out, it might answer some questions you didn't know you had. |
