Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Unread 11-02-2011, 02:17
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
JAVA Printing
Hello,
Is there any way to print something from the code and have it display to the user?
Tired System.out.print(); and didn't see anything come up.
Thanks in advance
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 11-02-2011, 06:55
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: JAVA Printing
public void output(String text){
System.out.println(text);
Unread 11-02-2011, 13:19
Ben_R_R's Avatar
Ben_R_R Ben_R_R is offline
Assistant Programing Mentor
FRC #2194 (Fondy Fire)
Ben_R_R is an unknown quantity at this point
Re: JAVA Printing
That prints to the Net Beans console, useful for debugging, not so useful in competition though. Does any one know how to print to the Drive Station console?
2194 Alumni and Mentor
Unread 11-02-2011, 13:45
mwtidd's Avatar
AKA: mike
Re: JAVA Printing
printing to the driver station you only have 7 lines or so, and you have to replace previous lines. So utilizing it for debugging is a little difficult.
it doesnt work like a typical printf where you can keep going.
Unread 12-02-2011, 13:25
morganfshirley morganfshirley is offline
FRC #1571 (BraughtWurst)
morganfshirley is an unknown quantity at this point
Re: JAVA Printing
To output text to the Driver Station, you must create a DriverStationLCD object. Once it has been initialized, lines can be outputted using:
[DriverStationLCD object name].println(DriverStationLCD.Line.[line],
    [Priority], [message]);
You will also need to use a .updateLCD() command to get it to write to the Driver's Station.
Unread 12-02-2011, 13:48
Ben_R_R's Avatar
Re: JAVA Printing
Ah, yes that worked. For some reason I got a null pointer exception when I tried that before. It worked now though. Thanks!
