Go to Post FIRST has stated time and again that the program is not about teaching (they always refer to the I and R in FIRST) - Dave Flowerday [more]
Unread 11-02-2011, 19:15
evilcrouton evilcrouton is offline
FRC #2851
evilcrouton is an unknown quantity at this point
CRIO Dip switch broken
The safe mode dip switch seems to be broken on our crio and is therefore stuck in safe mode. Does anyone know how we can get off safe mode?
Unread 11-02-2011, 19:30
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: CRIO Dip switch broken
You could open the cRio up and see if removing the case will allow the switch to move. You should probably contact a NI rep for help if you cant get it back. They are very friendly and helpful!
{Disclaimer:I have not done this} Or you could manually break the connection of the dip switch if it does not want to move. This could be done by unsoldering the switch. Make sure you are statically grounded when you open up the crio and that there are no metal chips on the crio as these can fall in and cause a short circuit. We short circuited our cRio last year, so be very carefull.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 11-02-2011, 20:27
FRC #2851
I already opened up the crio and tried to see if i could move the switch but it didn't. I was thinking of desoldering the dip switches and installing a new one. Does anyone know where i may obtain one? Also, I will try to contact NI before doing this
Unread 12-02-2011, 00:24
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Often if you call NI, you can RMA the cRIO for a broken DIP switch. If you do any soldering on it, that will void the warranty.
