Go to Post Remember guys, if your mentor wasn't there, odds are, you wouldn't be either. - Corey Balint [more]
Unread 11-02-2011, 21:21
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
This Code worked, then it didn't
Hello, I have made code for my team's minibot deployment system. It worked once, then never again
package com.robototes.abomasnow;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.Timer;
public class MinibotDeployment {
    Jaguar armSwingyMotor;
    LimitSwitch thePole;
    MinibotDeployment(int vicPort, int swiPort) {
        //the thing that sets crap up
        this.armSwingyMotor = new Jaguar(4, vicPort);
        this.thePole = new LimitSwitch(swiPort, 14);
    void hitThePole(Driver robot) {
        robot.stop();
        double time = Timer.getFPGATimestamp();
        while ((Timer.getFPGATimestamp() < time + 5.0f) && this.thePole.getLeftWays()) {
            System.out.println(';');
            this.armSwingyMotor.set(0.25);
        this.armSwingyMotor.set(0);
    void resetArm() {
Limitswitch:
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
import edu.wpi.first.wpilibj.DigitalInput;
public class LimitSwitch {
    DigitalInput one;
    DigitalInput two;
    LimitSwitch(int port, int otherPort) {
        one = new DigitalInput(4, port);
        two = new DigitalInput(4, otherPort);
    boolean getLeftWays() {
        return this.one.get();
    boolean getRightWays() {
        return this.two.get();
    boolean[] get() {
        boolean[] foo = {this.getLeftWays(), this.getRightWays()};
        return foo;
resetArm is supposed to be blank.
Where did I screw up?
Last edited by Robototes2412 : 11-02-2011 at 21:39. Reason: forgot LimitSwitch code
Unread 11-02-2011, 21:59
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: This Code worked, then it didn't
public MinibotDeployment(int vicPort, int swiPort) {
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 11-02-2011, 22:10
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Originally Posted by Robby Unruh View Post
I do agree that it should be public but I'm thinking he is saying that he ran the code once and it worked but didn't work after that.
Unread 12-02-2011, 12:23
1 * 4 != 14
Everything in my code is mono-package by design.
the minibot deployment is called as
MinibotDeployment rusty = new MinibotDeployment(3,5);
The robot gets stuck in the loop and no PWM values are set
Unread 13-02-2011, 20:46
AKA: Bryant
Easy answer don't use loops. When you trip the watchdog it cuts output.
You should look at possibly using a state machine or schedule a TimerTask to complete your operations. As is its preventing communications with the driver station and/or the rest of the code.
Example
change
To something like
final double time = Timer.getFPGATimestamp();
java.util.Timer timer = new java.util.Timer();
timer.schedule( new TimerTask()
    public void run()
        if((Timer.getFPGATimestamp() < time + 5.0f) && this.thePole.getLeftWays()) {
        else
            this.cancel();
}, 0, 50);
This will call the run method every 50 ms starting immediately.
Why call a timer to set the motor to .25 instead of setting the motor to 0.25 then creating a timer to stop the motor? To avoid the motor safety shutting it off
Unread 13-02-2011, 21:23
1 * 4 != 14
ok, thanks for the code. We found that the problem was a freaking pwm cable dying on us. >_<
class team2412(GP):
    def __init__(self):
        GP.__init__(self)
        self.coopertition = True
        self.info = {"name": "Robototes", "school": "Sammamish High School, Bellevue, WA"}
        assert self.kind_people == True
Unread 11-02-2011, 22:09
AKA: Bryant
--SNIP--
It appears that the robot read your comment and didn't like it!
JK
Is there a better way to do this?
If you use the loop but never reach the limit what happens to the rest of the robot code?
P.S. what "didn't" work?
Did the robot stop working? If so it appears that you tripped the watchdog.
