Go to Post It's too late to turn back - the only way is forward. Together - with a plan. - JaneYoung [more]
Unread 12-02-2011, 12:38
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Axis 206 camera
How do you program the axis 206 camera motors. I believe it has servo motors to move it but how do I program it. If someone could post a basic code for it that would make it work, I would greatly appreciate it.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 12-02-2011, 13:04
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
Re: Axis 206 camera
see what I have posted for help with programming I think I posted after you did, it is titled "help with servo programming", it might help you.
Unread 12-02-2011, 13:46
Slothbron's Avatar
AKA: Nathan
Re: Axis 206 camera
ok I looked at what you posted I will give it a try.
MRT 3216
Unread 12-02-2011, 20:34
Re: Axis 206 camera
The default code from 2008 did a servo mounted camera, and because of that, there is a Two Color Servo Camera Example that ships with LV. You can open it form the Help menu or the getting started. The code is a bit complex because it was trying to quickly process and follow the green/pink cylinder, but you can see how the bottom loop moves the camera around.
Greg McKaskle
