Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
Unread 12-02-2011, 15:34
bradley.gustav bradley.gustav is offline
FRC #3642
bradley.gustav is an unknown quantity at this point
programming a limit switch
how do you program a limit switch on c++?
Unread 12-02-2011, 15:50
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: programming a limit switch
Should probably search Chief Delphi for answers.
However, you would use a DigitalInput object (http://mmrambotics.ca/wpilib/class_digital_input.html) and use the Get() function to check whether the switch is high or low.
The correspondence of TRUE to HIGH or FALSE to HIGH is dependent on your wiring.
