Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 12-02-2011, 18:30
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Could code cause a communications error?
We had an issue today of communication. The robot would disconnect after a few seconds no matter what. We updated and used the defaut myRobot file and it is fixed. The cause is believed to be jointly a corrupted v27 update and possibly an error in our program, which is here.
Is it possible for a program to create an issue like this, and if so, is our program at fault? The program is a work in progress, but if you see any other mistakes please point them out.
Unread 12-02-2011, 18:43
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Could code cause a communications error?
Your code looks fine, and while code can frequently fail to run (which can be mistaken for a No Robot Code error) or cause watchdog timeouts - I don't think code can cause a communication error.
I would highly recommend reimaging.
